Question about Sony Playstation 3 (PS3) Console
How do I find Out what my WEP Key is. (play station)
    New Friend:
    Problem Solver:
  • 9 Answers
Whenever I need my WEP key, I log into my router. Try typing this into your browser address bar.
192.1268.1.1
It may be different depending on your router / modem.
You'll then need your router's username and password.
The default could be: "admin" and "admin"
Once you gain access, the WEP key should be immediately visible or you may have to go to the wireless section.
Posted on Nov 28, 2013
  • Jim Power
    Jim Power Dec 02, 2013
    That should have been 192.168.1.1
I have play station 3 how should it show up when checking should it be under a WEP Key I do not understand how all this works I just want to make sure everything is done right so I don't have
The PS3 has 2 different ways it can connect. The first, and most reccomended, is by a ethernet cord to your router directly. The second, is by wifi. When you connect wifi, you go to network settings, it will suggest wired but you can continue with wifi connection, then select "wireless". It will ask you to auto scan, or manually put in the SSID. Select "Auto" then when your router info shows up, it will ask for the security info (WEP) this is where you enter the security code that you use for all of your devices that use the wireless connection. If the key is correct, it will ask you to test your connection. Everything is automatic from there.
Oct 15, 2014 | Sony Playstation 3 (PS3) Console
What is a wep key?
In Shared Key authentication, the WEP key is used for authentication. A four-way challenge-response handshake is used:
  1. The client station sends an authentication request to the Access Point.
  2. The Access Point sends back a clear-text challenge.
  3. The client has to encrypt the challenge text using the configured WEP key, and send it back in another authentication request.
  4. The Access Point decrypts the material, and compares it with the clear-text it had sent. Depending on the success of this comparison, the Access Point sends back a positive or negative response.
for details kindly visit the link
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
I try to make my radio connect to the internet and when i say that i have a wireless connection and i type in my wireless passkey it accepts it but when it tries to connect it says it is unable to get IP.
I had this problem. Let me give some background. I was listening to my radio, to an internet radio station. There was a power surge/blip - a big thump. My radio is in the bedroom and the computer and router are in the living room. The power surge didn't even restart the computer or router, but the radio stopped playing the streaming station. I restarted the radio and it would not get an ip. I restarted the computer, router, and also my netbook that connects wirelessly. The netbook connected to the router and got an ip using the existing WEP key. I reset the radio and re-entered the WEP key into the radio setup and it still would not get an ip. I unplugged the radio and let it sit for a while hoping it would reset. Started the radio back up, entered the WEP key and still it did not get an ip. I went into my router software thru the computer and it actually showed the radio as an unassigned guest (or some weird nomenclature), so I knew the radio was connecting to the router it just wasn't getting an ip. So I went into the router manual setup function and re-entered the WEP key (the same key that I have been using). Before I exited the router maintenance program I looked at status and it had already assigned an ip to the radio. So somehow the power surge corrupted the WEP key data in the router. I went back into the bedroom and hit the OK button on the radio to "request an ip" and it connected immediately. So I am sorry for the long answer, but this may help someone in the same situation. I know in the future that if I run into this type of problem, that I will first re-enter the WEP key thru the manual setup in the router first!!! Thanks.
Jan 08, 2011 | Aluratek AIRMM01 Internet Radio Alarm...
How do i find out my wpa/ wep key for my xbox 360 to configure the wireless connection ?
The WEP/WPA encryption key is configured in the wireless settings of the wireless router. Go into your router's wireless settings to get this encryption key and the SSID, note these settings you need to configure the Xbox 360 with these settings.
For instructions on configuring the Xbox, please click on this link and follow the instructions :-
http://fixhomenetwork.com/xbox-play-station-wii.php
Jul 10, 2010 | Computers & Internet
Where do i find the WEP address?
WEP key is assigned by your network administrator.
Apr 17, 2010 | Microsoft Broadband Networking MN-500...
Cant find my wifi code to open a network
Your WEP is the security key you set in your router to allow other authorised devices to access your network. When you set it up, you set the WEP to protect your network from others accessing it without the key. So now all you have to do is set the WEP (security) key in your laptop the same as your router and you're cookin'. The same key must be used to connect any thing, iPhone, Wii, Play Station, anything that has WiIFi capabilty.
Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
Its a xbox wireless network adapter what is a WEP key where do i fine this
The WEP is the encryption key that is configured in the wireless settings of your wireless router.
I recommend you configure your wireless router with WPA encryption as WEP is an old encryption method and it is easy to hack into.
To secure your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
To configure the Xbox, please click on this link and follow the instructions :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Jan 18, 2010 | AT&T ATT00966 ATandT Model 6850G Wireless...
I can't find the WEP code and need to gain access for a new computer. I no longer use the computer where the software was originally loaded. Can i get the software to download from a website? or how can I...
to get the WEP key , you will need to access the routerset up. the WEP kwy is the security password for your wireless network and that is set up on your router. Do you have any other computer connected to the router? If not then connect 1 computer to teh router. open the set up page of the router and you will get the wep key. Click Here for step by step solution
Nov 15, 2009 | Microsoft Broadband Networking MN-500...
How do I find out what my wep number is. lost the manual
You can locate the Wireless Network Security key (WEP key) by login to the Access Point or Router.
Or using any third party utilities which will scan the saved WEP key from the Computer.
Good Luck!!!!!!!
Oct 28, 2009 | Apple AirPort Extreme Base Station
Wep key
it all depends. There is usually a way to set it if you connect directly to the router, with a cable, then open up the website 192.168.1.1
When you open that up, you will basically be viewing your router's web page, and in the wireless security settings you can manually set your WEP key. these settings are in different places for different routers, but that's the general idea.
Aug 10, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
