Question about Pioneer VSX-1023-K
Blu ray player hooked up to receiver but no video pass through
Audio plays through the receiver but the video is not passed to the tv.
techman
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
issy2
  • 460 Answers
SOURCE: pioneer 92txh component to hdmi passthrough
check for input...? if so then connect to it and bring it to the mode...!!!
Posted on Feb 15, 2008
SOURCE: vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Posted on Sep 07, 2008
  • 120 Answers
SOURCE: Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Posted on May 20, 2009
electrotech1
  • 1126 Answers
SOURCE: I have a Pioneer SC-LX73.
It is not going to work because that reciever, is not made for that audio signal.
Posted on Jun 24, 2011
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
Have a HD cable set-top box and a blu-ray player both of which would be better with HDMI input and of course an HDMI out to the TV. But the NAD T742 doesnt have any HDMI in/out. Any idea how I can fix...
If this is your system;
http://www1.epinions.com/specs/pr-NAD_T742_5_1_Channel_Home_Audio_Receiver
It has two "digital optical" inputs for sound. The video doesn't need to pass through the receiver so, your HD components, box and Bluray player, should hook to TV directly then, providing your TV has digital optical out, you could run your audio out of the TV from a digital optical out, to receiver. This would allow you to select your video through your TV's menu and the sound would come through the receiver through the one input. You can pass your video through the receiver but, it doesn't have the best outputs to handle it. You also may notice lags beteween the audio and video if you go this route.
May 22, 2011 | NAD T742 Receiver
I have my cable box hooked up with HDMI and it works great. I have my blu ray player hooked up with components (R,G,B). Im not getting audio or video this way. Can anyone help?
Keep in mind that while HDMI will pass audio with video over one single cable, the Component connectors (RGB) although being 3 cables only passes the video signal, you will also need to connect up a separate connection from your DVD player to you receiver for audio, be it analog (red/white RCA connectors) or optical
Be sure to specify in the DVD's on screen menu which audio output you choose as audio may not pass out all available connections unless enabled. You may also need to select which video output you are using.
As far as not getting video, just be sure you connections are correct (red to red) etc as this would explain the no video...
I hope this helps,
Magoo
Mar 06, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
Will the Sony STR-DG820 receiver support 3D?
I have this amp and mine does not have the latest firmware (indicated by a green or blue dot near the serial number) and it does not pass through Audio or Video when a 3D Blu-Ray is played in my PS3 although my TV (Sony Bravia XBR-52HX909) does say "3D Video Signal Detected." No audio or video ever plays but the PS3 looks like it's playing.
Dec 31, 2010 | Sony STR-DG820 Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Sound with HDMI but no video
the Denon does not pass 1080p change the output res from the DVD/PS3 or Xbox to 720p or 1080i will solve the problem
Nov 18, 2008 | Denon AVR-2807 Receiver
Can i hook up to my satelite dish direct or do i have to go thru my receiver first. Thanks; Delmar currah@mts.net
The satelite dish will not pass-through the video/audio from your DVD player. You will need to find an open area (preferably DVD selector) on your receiver to input the DVD video/audio. Most satelite boxes are one way devices.
Satelite box --> Receiver (satelite input)--> TV
DVD Player --> Receiver (DVD Player input) --> TV
or
Satelite box --> TV
DVD Player --> TV
Mar 13, 2008 | Televison & Video
Pioneer VSX-1023-K Logo
23 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
