Question about Dell XPS™ 600 PC Desktop
Cant reinstall windows because it sayd it cant find a hard drive
My hardrive recently broke.I bought a new hard drive from dell.Im pretty sure i plugged it in the same way as the old one as its not very comlicating.
So now i go to reinstall windows on the computer and it loads up everything from the reinstall cd and then says 'setup is starting windows'
I then get a message sayin that the computer doesnt detect a hard drive.
I tried multiple thing and rechecked connections many time w/o any luck.
All i did when i put the new hard drive in was pull the old 1 out and pop in the new.I tried doing a diagnostic test on the computer/hardrive.
i intsantly get this 'Error Code 655D:0009
Msg:DEVICE_INITIALIZATION_FAILURE Unable to access USB''
I dont know what this means or what to do to fix it . Any help is greatly appreciated.
  • purplehaze_4 May 09, 2009
    Im not sure if its an IDE harddriver or if it was i dont know what jumpers are.ill be little more specific on what happening exactly.
    I put in my cd that has windows xp and other things too i got from dell.
    Blue screen comes up , says 'windows setup' top left and on the bottom it shows whats loading up.After it loads everything up it says 'setup is starting windows' either it gets stuck here or i lose patience after 2 hours OR it goes to the next screen which i get 3 options .
    Opt#1 install windows xp F1
    Opt#2 repair windows xp F2
    Opt#3 Exit and reboot F3
    If i chooseoption 1 or 2 i get to the next screen that says it could not find a hard drive and to check connections or something like that.
    it then says press F3 to exit and reboot and couple time it actualy gave 15 seconds timer till it self rebooted.
    I did reseat every connection and the hard drive is making normal sounds and it is a little warm.I even tried to put in my old hard drive in which the systems32 is corrupt to it doesnt start so i went thru the same process as with the new hard drive and i get the same cannot find hard drive thing.I did run a full diagnostic on the harddrive and it passed all tests.One thing i did notice when i was inside the comp resteating connection was what look like to be 2 blown/burned out capacitors on the motherboard, they are slight bulged and have brown residue on top, i may be wrong about this but i just thought i'd throw that out there.than you very much and again any help is greatly appreciated.
  • 433 Answers
Two things, check your jumper setting, if it is an IDE hard driver.
Second the computer usually won't recognize the Hard drive until it is formatted for the first time. Did the computer stop and say it could not find hard drive ? and you got F1 to continue, well if you did, just continue. Error 655D is a registry screw up, unplug your usb stuff if you can. remember your drivers aren't installed yet (usb requires drivers-once windows is reinstalling your get the drivers...good luck if you need any more help, just let us know
Posted on May 09, 2009
  • John Viguers
    John Viguers May 11, 2009
    Yea you bet you found it, and don't throw that other hard drive away just yet either.
    the ole dome capacitor trick...yep that will just about do anything weird, i went through 8 dell sx-270s with leaking capacitors , I would think about a new motherboard...
    G O O D E Y E....
    one thing that seemed to make me think that it happened, there was a bad bunch manufactured and too I think that heat maybe pushed the process along. So cpu cooling and fans large enough that there is good circulation and no hot spots in the puter.
No boot device available
It sounds like your hard drive may have stop working. Or your operating system may have been corrupted. You can try to restore your computer with back up disks. Or try installing a fresh copy of windows. If the hardrive is not working try a new hard drive and reinstall the operating system. Here is a link for the documentation for your computer: http://search.dell.com/results.aspx?s=dhs&c=us&l=en&cs=19&k=no%20boot%20device%20error&cat=sup
Oct 03, 2013 | Dell OptiPlex GX620 PC Desktop
ERROR CODE 0F00:065D
If your hard drive shows as empty, you should be able to reinstall your operating system from the system disk.
If the disk has failed, though, it will not accept the operating system. You'll have to buy a new hard drive.
In a Dell computer, if you press the special function key to select a boot option (I think it's F12), one option should be diagnostics. Here you can test the hard drive. If it comes up with an error, you'll know for sure what the problem is.
Feb 29, 2012 | Dell Vostro 1014 Laptop Computer
My hardrive recently died, and so I bought a new PATA drive to go with my Soyo KT333 Dragon Lite motherboard. I get an error message when I try installing the drive, saying a disk read error occured, hit...
Is your hard drive being properly recognized/ identified in your Bios you may have to check in there
as far as partitioning goes you should be able to do that when you reinstall the Operating system in the advanced mode depending on what operating system of course.
Dec 21, 2010 | Computers & Internet
Start up problem
Restart the Laptop and press F8 you will get a option that sayd repair my computer select the option,
If repair mu Computer doesn't work than go to BIOS and check if the Hard drive is detected in BIOS or not and than perform Hard drive test in BIOS there is utility which will allow to perform the test of hardwares.
If Hard drive is detected in BIOS nad Hard drive test passedthan you need to reinstall the windows.
If Hard drive test failed or it is not reflected in Windows than replaced the hard drive and install OS on new hard drive.
Thanks and Regards
Jul 05, 2009 | Compaq Presario 700 470024-192 Notebook
I cant login to my myspace or facebook account. whats wrong?
im in the emergency room and im using their laptops but when i try to sign onto myspace it wont let me wats the problem
Apr 06, 2009 | Dell OptiPlex GX150 PC Desktop
Why cant I Format the hard drive on a dell pc
when the system is u and running normally the comp is using the hardrive to run your computer to format it you must enter the installation of xp and format the disk during the installation process. there is a part of the installation where if theres a o/s on a harddisk it will allow you to format it just make sure you format it to NTFS if will be one of the selections
Mar 25, 2009 | Dell OptiPlex GX260 PC Desktop
OS problem
This is most likely going to be a failed hard drive. Since it won't load the system, by general rule, If the hard drive won't format, or if you have any issues during or after the set up of a new operating system, then the hard drive is shot, and needs replaced. Replace the drive and you should be just fine.
Aug 25, 2008 | Dell Inspiron E1505 Notebook
Toshiba windows xp problem
hi friend
ur windows xp cd is corrpat to make new copy of ur windows xp cd & try to install if not insatlls bye the windows xp cd
or try to install onther from the onther cd
if problem occers then u have to repartioin of ur hard drive & try to install windows xp
thnx using fixya
Mar 31, 2008 | Toshiba Satellite M45-S265 Notebook
Reinstalling windows on new hard drive
Place the windows cd in the drive and re-boot.You should be prompted to press any key to boot from the cd.After that,just follow the on-screen instructions.It's really pretty simple!Hope this helps!
Feb 20, 2008 | Dell Dimension 3000 PC Desktop
Dell XPS™ 600 PC Desktop Logo
376 people viewed this question
Alun Cox
