What percent is 46000 of 35000000? - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
About 0.131%
Posted on Sep 13, 2014
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
2.7030 is what percent of 100
If 1 is 1 percent of 100 and 2 is 2 percent of 100, it follows that 2.7020 is 2.7030 percent of 100.
Oct 31, 2014 | Office Equipment & Supplies
Percent of change
20 percent.
Mar 30, 2014 | ixl.com
Percent of increase
change =(new value-old value)/(old value)
Percent change =change*100 %
change=(8900.00-8640.00)/8640.00=0.0301
Percent change=0.0301*100%=3.01%
Since the change is positive, the new value is higher than the old value, this change is an increase.
Percent increase=3.01 %
Mar 05, 2014 | Office Equipment & Supplies
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
How do u get % on it
On calculators you do not usually get percents. Instead, you get values which can be converted to a percent. For example what percent is 245 out of 987. You divide 245/987=.248. This is essentially the same as saying 24.8 percent. You move the decimal over 2 values. You can also round to get a nice percent number such as 25 percent.
If you are trying to put in a percent lets say you have to find 47% of 80. You just multiply .47 * 80= 38.4
Jun 14, 2011 | Texas Instruments TI-84 Plus Silver...
I raised $948,963 last year. I raise $ 817,430 this year. Is that 9% less raised this year>
No.
You can divide this years by last year and that gives you the percent you got this year compared to last. You raised about 86 percent of what you raised last year. so 100 percent minus 86 percent. That is equal to 14 percent. You raised 14 percent less this year.
Jun 14, 2011 | Office Equipment & Supplies
Increase percentage of 70 to 200
A percentage increase from a value a to a value b is defined as
Percent increase=(b-a)/a*100 percent.
In your case it is (200-70)/70=1.857. Multiply this number by 100 and append the percent symbol. Thus increase=185.7 percent or about 186 percent.
May 05, 2011 | Texas Instruments TI-83 Plus Calculator
CHECK ENGINE LIGHT ON CODE P0170
DTC P0170 applies to fuel trim malfunction on all 2.4L vehicles, 3.0L Federal vehicles and right bank (bank 1) on 3.0L California vehicles.
DTC P0173 applies to fuel trim malfunction on left bank (bank 2) on 3.0L California vehicles.
DTC Set Criteria (2.4L)
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). Volume Airflow (VAF) sensor output frequency is 88 Hz or more. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds and short-range fuel correction is less than -10 percent, or more than +10 percent, for 5 seconds.
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). VAF sensor output frequency is less than 88 Hz. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds. On 2.4L code will also set if short-range fuel correction is less than -15 percent, or more than +15 percent, for 5 seconds. On 3.0L Federal code will also set if short-range fuel correction is less than -13.5 percent, or more than +13.5 percent, for 5 seconds.
Have the O2 Sensor changed on the Right Bank, ( passenger side of the Engine, or where the # 1 cylinder is.)
Good luck and hope this helps
May 02, 2009 | 1997 Mitsubishi Mirage
21 people viewed this question
k24674
