Question about Sewing Machines
Thread keeps on jamming under the metal plate below feed dog, and fabric will not move. Tried changing needles, thread, re threading etc...but to no avail.
The fabric will not feed through, and jams, and when I look under the plate, there is jammed globs of thread. The bobbin seems to be ok. It's the top thread.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sewing Machines Master
  • 102,366 Answers
What make and model sewing machine?
Posted on Nov 28, 2013
4 Suggested Answers
ladya2004
SOURCE: needle thread will not pick up bobbin thread
I finally had to take it in for repair at Sears
Posted on Apr 01, 2012
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
Every few stitches thread gathers and jams on bobbin side of fabric. Why? [the machine is a Singer model 6180]
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Sewing Machines
Loose thread on bottom of fabric and locks up needle
Change needle
& bobbin
Nov 23, 2010 | Toyota STF17 Sewing Machine
When I try to sew, the thread on the bottom of my fabric gets all bunched up. Sometimes the needle gets stuck. This happens all the time. I re- thread the whole machine, but it always eventually happens...
put a new needle in the machine
clean under the needle plate in the feed dog area for lint
also clean in the bobbin area for lint & loose threads
keep a check on the thread take up lever,, because when the thread comes off the thread take up lever it will build up thread under the fabric & can jam up the sewing machine
Nov 17, 2010 | Elna 1010
Thread is balling up and not allowing the fabric to move it isn't stitching right
This can be caused by several different things. Check the threading. Un-thread the machine and follow the guidance on the manual and re-thread the machine. The bobbin, if the bobbin thread that coming out of the bobbin case in a wrong direction, could cause this. Re-set the direction. When you pull thread from the bobbin case, bobbin should roll counter clockwise. The needle, if it is not the right size needle for the fabric or the needle is slightly bent, maybe replace the needle and try with different size of needle. Once its balling up, sometimes it's left some thread in the machine under the needle plate around the feed dog, clean them up. Thread tension, different fabric may need to be adjust the thread tension, try to check this one under the manuals/instruction. When ready, check and use a scrap of fabric/remnants!
Aug 02, 2010 | Riccar Sewing Machines
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
409 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
