Question about Whirlpool Stove / Oven / Range Pilot Thermocouple - W10155906
Where is the Pilot for my whirlpool oven - Whirlpool Stove / Oven / Range Pilot Thermocouple - W10155906
    Scholar:
    New Friend:
  • 81 Answers
If you have a pilot light, it's in the oven section you take the bottom plate off with the 2 screws holding it on. It's going to be in the back by the burner valves. Most whirlpools don't carry pilot lights.
Posted on Nov 28, 2013
Pilot lock light on stove is on so stove burners unable to work
This sounds like you may have to fix a problem in the pilot area before it will work. These gas operated devices have to meet a much higher safety standard than their electric counterparts. It is a built- in safety feature. Now, look for any obstruction or crimp in the gas line. My guess is you are not getting proper gas flow or pressure or the pilot could be physically blocked.
Feb 19, 2015 | Thermador Cooktops
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
Whirlpool Double Oven Range
Recycle the circuit breaker for the oven several times. If you haven't used the oven much the contacts may be corroded. The display is off a 110Vac circuit but the ovens use 220Vac, The circuit breaker should be 2 switches "ganged" together as one. Both should be cycled...
Dec 25, 2012 | Whirlpool GGE388LXB - Black GoldR Double...
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
PILOT LIGHT OUT. sTOVETOP CONTINOUSLY MAKES A CLICKING SOUND. i BELIEVE THE PILOT IS OUT. hOW DO i REIGNITE THE PILOT AND MAKE THE CLICKING STOP
Sorry to read about your problem, I hope this helps you out.
Their is no pilot lite on your oven..the clicking you hear is the electronic pilot system..
you have a defective control knob...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Cooktops
How to relight the pilot light?
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
Sep 19, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Pilot lights
unplug the unit if the pilot ligth is electric.then u can use manualy.
Nov 19, 2008 | Cooktops
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Whirlpool Stove / Oven / Range Pilot Thermocouple - W10155906 Logo
108 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
