Question about Westinghouse Refrigerators
Control touch panel not working - Westinghouse Refrigerators
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Try unplugginh for ten seconds and plug in to reboot system
Posted on Dec 01, 2013
Touch screen will not work
Try uninstalling your display drivers and let windows reinstall them for you...
Dec 06, 2014 | Computers & Internet
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 16, 2011 | Computers & Internet
Amana rfs12sw2a....1200watt The soft touch buttons don't respond except for number 6....
Sounds like a bad control board. First just check and make sure all of your connectors are in tight. Part numbers for the control board is 53001806 you could have a bad touch panel. rare and not typical but can happen part number for that is 53002019. I would probably buy both of those parts plug in the new panel into the existing control board and see of everything works. if so replace the touch panel and send the control board back. If it still does not work then swap the control board and send the touch panel back. hope that helps
Mar 19, 2011 | Amana RFS12MPS Microwave Oven
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Refrigerators Logo
37 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
