Kenmore elite dishwasher 665. error code F4E1
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
Posted on May 05, 2009
jsrock516
  • 5911 Answers
SOURCE: i have a kenmore elite dishwasher model#665. no
Nearly all Kenmore dishwashers have a thermal fuse inside the operator console. If the fuse blows, it will exhibit the symptoms you describe. If you post back with a COMPLETE model number (located around the tub opening with the door open), I can verify, provide you with a part number, and explain to steps required to replace it.
NOTE: "665" is the manufacturer code, which identifies the manufacturer of your dishwasher as Whirlpool.
Posted on Nov 18, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
  • 662 Answers
SOURCE: I have a F 06 error code on my kenmore elite front...
http://www.fixya.com/support/r3608706-f06_error_code
Posted on Jun 03, 2010
My kenmore dishwasher not working code f4e1 came on
I checked the searspartsdirect.com website, and according to them, it is a 'motor communication issue.' In order to get more details, you have to create a login, and it was taking forever to complete that, so I gave up.
Try flipping the circuit breaker, leave it off for 1 minute, then turn it on again. Do you still get the error code?
Okay, I finally completed the sign-up process. Here is some more info from an actual repair technician:
The F4E1 is a code that signifies a WASH MOTOR
issue. Specifically, no Communication. This is usually caused by: A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor. 1. Unplug dishwasher or disconnect power. 2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit with meter. Fix/replace an open connection/part. Motor fuse on control open. 1. Start Service Diagnostics Cycle using keypad and advance through the error code intervals to interval 19. ( shown on image below ) 2. Listen for 2 relay contact clicks at the start of interval 19 (to confirm both the pilot and motor relays are turning on.
NOTE : These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Faulty wash motor. 1. Unplug dishwasher or disconnect power. 2. Use inspection mirror to inspect for water leakage and/or overheating on the wash motor. If evidence of overheating exists, replace wash motor. If evidence of moisture exists, check seals and hoses.f you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Jun 11, 2014 | Kenmore 665
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
May 10, 2014 | Dishwashers
Error code F4E1 need reset
Turn off the power to the dishwasher for about 5 minutes before you power it up check that the water supply line is on. Also check for restricted drain area. Power it up and clear the power fail fault see if it works
Feb 24, 2014 | Kenmore 24" Built-In Dishwasher, Stainless...
Dishwasher f4e1
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
Feb 09, 2014 | Kenmore 665
CODE F4E1 will not go away
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Feb 09, 2014 | Kenmore 15322 / 15324 / 15329 Built-in...
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Manual for Kenmore Elite dishwasher
Kenmore Elite DIshwasher will not start. Model # 630.16302406
Display shows h:08 with the quick setting illumintated
Jul 17, 2012 | Kenmore Dishwashers
Kenmore Elite dishwasher: not doing anything.
turn off power an back on / if no change remove the toe panel and the tech sheet will be there . it will tell you what the code is and how to correct most .. mm hope this helped. pls leav feed back.
Dec 07, 2009 | Dryers
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
