Bizhub c452 Error code : C-3B06
4 Suggested Answers
  • 132 Answers
SOURCE: I have a Konica Minolta
Toler leak from yellow cartrigde. Change cartridge and carefully clean paper path.
Posted on Nov 13, 2010
  • 24 Answers
SOURCE: there is an error code
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Posted on Aug 21, 2011
  • 16973 Answers
SOURCE: Konica Minolta bizhub c452 makes clicking / ticking noise. also has color streaking.
This is a sign of wear if you can check the internal mechanics of the printer when it is running, you will see that there is a gear issue.
Posted on Feb 26, 2013
Konica minolta c 452 error code c 2161 & 2164
Hi
The descriptions for the two error codes you mention can be found at the two links below:
Error Codes Konica Minolta bizhub C452 Code C2164
Error Codes Konica Minolta bizhub C452 Code C2161
They would appear to be related to the same problem. For further information I think you would be best going to this page: Konica Minolta bizhub C452 Manual where there are many different manuals for this machine, which can be downloaded by clicking on the one you require and then following the instructions.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Konica Minolta Office Equipment & Supplies
Error Code C-B302
not in manual probably Fax error
Apr 28, 2014 | Konica Minolta Bizhub C452 Copier
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
TROUBLE CODE C173
Have a tech come out re-flash th copier os and also check the NVRAM board firmware, mite also be the control board
Error c-3425 on bizhub c452
hi
in table number vg blak unit image is 914
i replase unit image blak developing tank
please help me
Nov 15, 2012 | Konica Minolta Bizhub C452 Color Copier,...
Konica Bizhub C452 Error C-3B02
chek your register conector
open the front door and clean conector
May 26, 2012 | Konica Minolta Bizhub C452 Copier
327 people viewed this question
k24674
jasbo
jasbo
