Question about Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7
IP Address unavailable/ cannot hook up to internet
I Have 2 Mach Speed Trio Steath G2 tablets. One hooks up to internet just fine, the other one will not connect. When I try to turn on wifi in settings, it turns itself off and will not connect. My status states the my IP address is unavailable! My Wifi mac address is unavaible, and my serial number is unknown. What happened and how do I fix this
    Problem Solver:
  • 6 Answers
Has it been rooted?
The equivelent of a an ipad/iphone jailbreak?
You can check this by doing one of two things.
The first is by going into settings, scrolling down to the bottom and clicking on About Tablet.
If not that then go to Settings/Device and then click About Tablet.
The second, and easiest, is to check to see if you have an app called SuperUser (SU).
If you do then your device is rooted.
Other ways to check, which is more dificult because of you not being able to get WiFi access, is by downloading an app called Root Checker or a Terminal app.
Root checker is self explanitory as it does exactly what it says on the tin.
It will check to see if you have root access to your device and will tell you either way.
The terminal app will show a hash tag symbol (#) as soon as it is started.
This is also an indicator of root access.
Have a look in the WiFi/network settings for your device and see if it has been set up to use a proxy or VPN.
If it has then clear these settings and try to enable the WiFi again.
If this doesn't work then i would restore the device back to factory settings as it could be a software issue.
Failing that you could always upgrade the firmware to the new 4.4 KitKat which, if your device is rooted, will wipe root access out.
Posted on Nov 28, 2013
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
May 13, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
I can not connect to internet with my stealthg2 eventhough wifi strength strong
check to see if it's doing MAC filtering(turned on) if so you need to add your mac address for the device
Dec 27, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Oct 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth g2 just shows start up screen won't boot up
my table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
Aug 11, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
214 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
