Question about Keurig B70 Coffee Maker
Water keeps comming out
Water keeps coming out while trying to prime
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Posted on Jan 06, 2014
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
Machine says needs priming. Water light stays on but no water comes out when opening valve. No water for coffee either. Water pump broken?
hi,
can you hear a quite louder noise when trying to make water flow?
If no or very faint noise can be heard, pump is probably faulty or needs to be disassembled and cleaned (see tutos on the Net)
If you can hear a loud noise, the pump is working but unable to suck water, keep on trying, if still unsuccessfull you will have to open the machine and fill yourself the watel inlet tube to "help" the pump priming.
Hope that thelps
M
Apr 24, 2016 | Saeco Incanto Classic Espresso Machine
HOW DO YOU PRIME THE KERIG
Remove the water reservoir, then reinstall it to it's normal position. Refill or top off with the recommended bottled or filtered water to the max fill line.This will clear the prime message. If after you do the the above procedure at least two times, the prime message keeps coming back your machine has brewed its last coffee. If you bought it from Costco, I would recommend returning it there. Or If still within the 12 month warranty period, call Keurig.1-866-901-2739. Tell them and they will ship you a replacement.
Oct 11, 2014 | Keurig Platinum B70 Coffee Maker
Water pumps turns on but o No water comes out of
Sounds like the pump needs priming. There must be a plug on top of pump. Remove this and fill the pump with water to top. Replace cap an turn on. If keeps loosing prime, you either have a fauly nrv, non return valve not opening or you dont have one at all. Essential bit of kit.
Aug 16, 2013 | Cars & Trucks
MY PRIME LIGHT KEEPS COMING ON --I HAVE FOLLOWED THE INSTRUCTIONS IN THE BOOK BUT IT KEEPS HAPPENING
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
Shallow well pump every two days losing its prime it takes five cups of water to re prime
You should have a check valve installed on the incoming water line ( suction line) of the pump. This should keep the water from leavin the pump. if you still need to prime then there is a leak on the incoming line from the ground to the pump and you will need to have a well company come out and install a new line.
Sep 15, 2010 | Plumbing
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Can't prime new machine
brand new machine you put water in the container prime it with turkey blast open the valve on the side off machine and it still does not work tank good for warranty cheers
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Priming problem
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Oct 21, 2007 | Starbucks Saeco Italia Digital Barista...
Keurig B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
