Question about Dryers
Whirlpool dryer manual
How do you change the belt for dryer
  • 39 Answers
You don't give make/model. Call back with more info.
Posted on Nov 28, 2013
3 Suggested Answers
  • 15 Answers
SOURCE: changing dryer belt
The drive belt goes around the drum near the rear. It does not use a special groove; it just runs on the surface of the drum. You will need to remove the drum to gain access to the broken belt, motor, and idler/tensioner pulley. It will make more sense when you remove the drum and view the motor pulley and belt tensioner. With a helper, install the new belt around the motor pulley and under the tensioner, then fit it around the drum little by little as you reinstall the drum. Make sure the drum is positioned properly on its rear support wheels, then manually support the front end and rotate the drum slowly by hand. It should rotate freely and the belt should start to track straight as it realigns itself on the drum. If it tracks well, reinstall the front panel, door, top, etc., and check operation.
Posted on Jun 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Replacing broken belt-Whirlpool dryer
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Nov 18, 2015 | Whirlpool Dryers
How to change dryer belt
You have to remove the drum, by disassembling the dryer. That process depends on the model.
Jul 19, 2014 | Whirlpool Dryers
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
http://www.repairclinic.com/Dryer-Belt-Diagrams
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
and
(Page 10 below link)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
Thanks for choosing FixYa,
Kelly
Apr 01, 2011 | Whirlpool Dryers
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Kelly
Mar 30, 2011 | Whirlpool Dryers
How to change a belt on whirlpool dryer Model LER4634EQO
Check out this page for good information on changing the belt. Good luck with your repair!
Mar 01, 2010 | Whirlpool LER4634J Electric Dryer
DRUM NOT MOVING ON WHIRLPOOL ELEC DRYER
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Jan 06, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool/roper dryer won't start hear hum noise but doesn't start
open the back where you can see the mechanical parts (motor / belt / drum / capacitor)
1. unplug the unit, see if you can manually turn the motor head
If not , then the problem is the Bushing or bearing
If yes, then your starting capacitor ( Small aluminum type like a can with wires on top) change it.
check also the belt if it is correctly aligned.
Nov 08, 2009 | Whirlpool Dryers
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryers Logo
Top Dryers Experts
