After changing main 2 capasitors, still screen is blinking when tv start and after 2-3 blinking , it was not worked. Help please. Polaroid tv/ model # tda-03211c
  • 59 Answers
If you find two capacitors gone, there are usually more. Look for others in that same area. Even if they don't have a bulging top, they could still be bad. Since they are usually cheap enough, it's worth a try.
Posted on Nov 28, 2013
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Have a TDA-03211C Polaroid TV. It doesn't turn on,
This is what you need to do:
1) Look to see if the power supply module has any caps with leaking/bulging tops.
2) If you do have any indicator lights on the front panel, then it means the Standby 5vdc power supply section is working for the main logic to operate. Look at the termnials of the power supply that is labeled with STBY5V or something like that. This is a MUST HAVE voltage to get th TV started.
3) When the power button is activated, it will send out turn on signal #1 to the power supply module to turn on the main 5vdc (for the rest of the logic ciruites), 12~16vdc (for sound power amplifiers), and the 24vdc (for the backlight inverter board). Another turn on signal #2 is sent to the Backlight on/off control pin on the inverter board. Signal #3 is for turning on the T-CON board LCD panel.
It uses all these turn on signal so when the TV is in standby/sleep mode it will not consume all these power to save electricity and pass Energy Star compliance.
So now you have some basic ideas how LCD TV works and what is needed to turn on the TV.
Check out those voltages before it is on and after it is on
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net.
Posted on Jun 14, 2010
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
My polaroid tv, model number-TLX-04240B, is having problems. The tv will turn on fine but then after a few seconds the screen will go blank, please help. Whats wrong with my tv?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 14, 2015 | Polaroid Televison & Video
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
I have sound but no pic on my polaroid hd tv model number tda03211c there is also a red light blinking in the back of unit when it is on
Hello; I am John at J D Electronics in Poland Maine. I have had a few Polaroid model TDA03211C in my shop that would show Polaroid on screen and then loose the backlights. but not always, but would still have sound and remote control abilities. Many of these Polaroids and Memorex 32" sets have the same design. There is the main board in the bottom of the large metal box with the power supply/ ivnverter board in the top. On a few of these I found opened Caps to the right of the 2 large ivnverter transformers on the left. These were labeled EC17 and EC18. They are 10ufd @ 450V and 105 degree C. Replacing these 2 caps has now fixed 3 of these sets. John
Apr 08, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
TV is blank and status light is blinking yellow
I think you have a powersupply problem. This model has had alot of problems with bad electrolitic capasitors through out the entire chassi assy. Because of the way the manufacture designed this unit you may be better off getting a Mitsubishi Authorised service company to fix it. If you feel confedent,
check the powersuppy for 2 electrolitic capasitors that are bulging on the top. They will be your culpirts. I believe they will be 25v 2500uf. But don't hold me to it.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Humming noise
change the filter capasitor of the main supply, the big capasitor .
Sep 14, 2008 | Philips Magnavox 27MS343S 27" TV
Model WS 73713, mitsibushi big screen TV. green blinking light on front panel doesn't stop blinking and tv will not turn on by remote or power button on panel
called a TV repairman. I know $65. to start service call but feel it will be fixed correctly in a timely manner.
Sep 08, 2008 | Televison & Video
After tv is on for awhile it starts buzzing
I have a polaroid FLM-323B flat panel Tv. After it is on for awhile the TV starts buzzing and the picture starts to blink in and out. Can you help me with this?
Aug 19, 2008 | Polaroid FLM-323B Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
