Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Driver model cl-fm801-alc
Where exactly is the switch for the air suspension compressor on a 2006 Buick Lucerne CXL?
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling, and loading conditions.
The system uses the electronic suspension control module (ESCM), ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, LR and RR suspension position sensors, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
What switch ? there are sensors at the wheels that control the system .
The system uses the automatic level control module (ALCM) with integral suspension position sensor, ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
The
Jul 10, 2016 | Buick Cars & Trucks
How to turn up the power on the midland 78 plus
Midland 78-574: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-976: {L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-999: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
I put these up due to not knowing which one you have
May 07, 2015 | Midland Radio Communications
Sound driver needed ALC 883, Realtek 5.10.0.5296
Get onlineand got to www.google.com In the google search box type: "AcerSupport" or "Realtek Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
You can also try Driver Guide at:
http://www.driverguide.com
May 12, 2012 | Mercury Computers & Internet
I have a soundcard I put in my pc , it is a Creative Labs - CL-FM801-S2C-AD Card, but windows 7 cannot find a driver for it, and I lost the driver disc ages ago. Is there any chance of finding the...
If Creative Labs does not have a Windows 7 driver for your model sound card, then the sound card is considered too old and they won't provide further support for this sound card. Creative Labs wants you to purchase a later model sound card.
Creative Labs WEBcam drivers are available from their WEB downloadsite - click on this link and select your model WEBcam to download : - http://support.creative.com/
Jul 02, 2011 | Computers & Internet
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
Where is the a.i.r. pump located
The air pump for the secondary air system (emission control device) is located under the battery. If you do replace it, replace the check valve too, it is on top of the exhaust manifold and connected to the pump with a hose. The check valve fails and ruins the pump. Source(s): http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide vacuum to the climate control when the turbo is putting boost in the intake manifold. The vacuum can come from an electric pump or from an engine driven pump, something like an old engine driven fuel pump. I needed an electric pump for my 765T, and all the wrecking yards wanted to sell me the engine driven form. (A new one was $500, and it wasn't that important to me.)
An engine that takes the engine driven pump will have a hole in it while the others will not have a hole. Source(s): 35 years maintaining my own cars, including 17 years with a 1985 765T
OR
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Aug 04, 2010 | 1998 Cadillac Catera
I need sound card driver ''Forte Media FM801-AU 0423 HBR50.00'' sunil_shrestha23@hotmail.com
http://www.opendrivers.com/driver/217940/fortemedia-fm801-sound-card-driver-windows-2000-xp-free-download.html
there ya go bud ;)
Jun 26, 2009 | Office Equipment & Supplies
Fortemedia fm801 pci controller driver
sound Card sigma tel high definition driver
Mar 26, 2009 | Computers & Internet
Iwant (ALC) head light system ....work normal
Pull out the ALC fuse from under the hood.
Dec 25, 2008 | 1999 Chevrolet Malibu
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
118 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
