Reset username - Computers & Internet
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
How can i reset the dlink
It have button for reset. click in 10 seconds.
iF YOU DONT WANT TO DO THAT, because it will reset to factory setting
So how to reset without lost username password?
type at your browser 192.168.0.1
FILL USERNAME AND PASSWORD. that is for modem router username and password.
if you never change,then try
USERNAME:admin
PASSWORD:admin
IT WILL OPEN IT USERNAME AND PASSWORD IS TRUE.
THEN GO TO MANAINTENANCE->REBOOT.
May 13, 2011 | D-Link DIR-600 Router
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
Need new password and user
Every company that makes routers etc... has what they call backdoor (default) username and password so if you lost or forgot your username and password there is still a way to get into the router........
so google the backdoor username and password for your router..... and follow these steps
The first step is to reset the router by pressing the reset button on the back......this could be tricky sometimes cause you need something that can reach the button.... the lights will blank if you hard reset is successful .....
Once you reset the router
Step two enter the backdoor username and password....
Simple
........If this does not work .......then hard reset was not successful or you found the wrong backdoor (default) username and password
Please leave a testimony and vote on solution...
Also feel free to ask more questions...
Apr 05, 2011 | Computers & Internet
Forgat password
how to change password in grand chase
Apr 03, 2011 | Belkin F5D8236-4 Router
I cant find out my router username and password, please help.
try these...
username: password: (blank means no password)
administrator administrator
operator operator
administrator
(less likely ones)
anonymous
user user
user public
PFCUser 240653C9467E45
If these all fail, reset your router and try again.
Mar 01, 2011 | Compaq (171979-001) Router
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
What is a username
A router has a default username and password the default password is usually admin and depending on what type of router you have the password for the username should be admin as well, however you may be able to leave it blank. Now if you are trying to connect to a router in your area and is asking for a network key this is a username and password that was setup. If you are trying to access your own router and forgot the username you can always reset your router however by doing this it will reset the router back to default settings simply press and hold the reset button for 15 seconds or until router restarts you may need a paperclip in order to push reset button.
Nov 15, 2010 | Computers & Internet
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
