Need to set "over the air" or "Antenna" reception. Attached ds converter and get Channel 3 clearly but no Other channels. Cannot search for channels, how? How to search for channels?
SOURCE: can't get any tv reception
How do you expect a picture, without any Signal input? Just get any Rabbit Ears Indoor Antenna. Ore, if u wanna first try out, just push a length of Electrical Wire approximately 3-4 feet long into the Antenna socket at the rear of the TV, and then do Auto search. You will be able to view a few local channels - tho a little grainy. If u are satisfied, good, otherwise, then get an antenna.
SOURCE: RCA TV model 32V420T - Auto channel seek
Hi there!
Check that the remote buttons or the buttons on the Tv has not become sticky or soiled on the inside. Good Luck, JUS004
SOURCE: Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
SOURCE: Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
SOURCE: No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
