Question about Health & Beauty
Change from kg to lbs on curves scale it used to be in pounds and just changed to kilograms on it's own
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: How do I change the scale to read pounds instead
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Posted on Jan 03, 2010
SOURCE: can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
SOURCE: Jobar international JB5413 large cap.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
Posted on Dec 29, 2010
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
How do I change from kg to pounds
There are many online calculators that will do the math for you. If you want to do it yourself, the formula is 1 Kilogram = 2.20462262 Pounds. If you don;t need to be that exact, just use 1 KG =2.2 LB
Apr 25, 2015 | Health & Beauty
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Sep 09, 2011 | Health & Beauty
Can not change from Kg to Lbs
Apr 02, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
How do I change the scale to read pounds instead of kilograms?
Oct 25, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Health & Beauty Logo
65 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
