Question about Charging & Starting Systems for Jaguar XJ6
Car starts registers about 9 on dash red led light stays on around battery simbol
1987 jag xj6 dash meter shows about 4bars the battery symbol shows red around it will not charge any higher it was showing 13amps
  • Jaguar Master
  • 14,363 Answers
Bad battery,go get one from Walmart.
Posted on Nov 29, 2013
Jaguar 1987 radio code reset failure
I can only advise you see the Jag dealer on this. I think you don't have the correct code and only they can check that for you in the factory data base for your car.
Sep 25, 2012 | 1987 Jaguar XJ6
My jag x300 well not start can you help me. thanks.
check the battery make sure it is charged if when u do charge it and it does not make a clicking noise when u go to start it then ur starter is bad u will need to buy a brand new one not a used one.
May 22, 2011 | 1987 Jaguar XJ6
Radio code for radio of a 1987 jaguar xj6
ring jag with the vin num and they will provide it for you
Mar 13, 2010 | 1987 Jaguar XJ6
Fuel mpg i get 9 mpg
check tire pressure, change air filter, check and clean fuel injection system, no fast take offs, keep at or below 60 mph, keep rpm's at or below 2,000, coast to stop(no fast stops
Oct 04, 2009 | 1987 Jaguar XJ6
87 jag xj6. Brake pedal spongy goes all the way
If the brake lines and fluid is clear then you may have to look at the brake booster found at the other end of the brake pedal under the hood...
Jul 23, 2009 | 1987 Jaguar XJ6
Something electrical is draining battery on 1987 XJ6;
Have you checked the alternator? The alternator may not be charging the battery. With engine running, check the voltage at the battery (it should be ~14V). If it's less than that, your battery won't charge properly. You can take your alternator to auto store to have it load tested also to be sure. Sometime alternator issues don't show up until it gets hot. Defective alternators have also been known to drain the battery after the car has stopped.
May 10, 2009 | 1987 Jaguar XJ6
1984 jag xj6 has no power
Hi Clyde
Expect you have it running by now, as I see this was posted 2 March ?
If not......
Charge up your battery, and heavy discharge test, suspect you have short in the plates.
If OK, jump start with a set of proper heavy duty jump leads.
Good Luck !
A FixYa would be nice...Thank´s......John.
Mar 03, 2009 | 1988 Jaguar XJ6
Ive turned of my jag in park mode, now i cant restart it
Does your dash light up to indicate you have a battery source or power? If yes you have power try starting it in neuatral or in another gear. If it starts in neatrual maybe your selector going bad. If it starts in other gears repair the shift selector. Three If no power indicated check fuses. four will motor crank or turn over if yes look for a drivability problem. If no final maybe bad ignition switch. Need to replace ignition switch. Probably time for service
Feb 27, 2009 | 1987 Jaguar XJ6
Ignition but no start
I have a 94 xj6 jag and after a blow out the car will not start. I pulled over and turned the car off. When I fixed the blowout it will not start. I have lights, power windows, sunroof, radio and dash lights but when I turn the key nothing. I cant even get it out of drive in first position. The guages doesn't function either, but the dash lights will. Can some one please help me!!!
Aug 01, 2008 | 1994 Jaguar XJ6
Charging & Starting Systems for Jaguar XJ6 Logo
49 people viewed this question
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Spyro Matiatos
Spyro Matiatos
Arnie Burke
Arnie Burke
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
