Question about Masterbuilt 20070106 Electric Smoker
Smoker displaying eaaf - Masterbuilt 20070106 Electric Smoker
Hair dryer worked in 2 min. thanks for the tip. one could also pre-heat the night before andleave the smoker at 100 degrees until morning.
Posted on Nov 28, 2013
3 Suggested Answers
SOURCE: Trying to start this smoker and it is showing me a
I am having the same problem
Posted on Jan 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Masterbuilt smoker model 20070910 with
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Kelly
Posted on Jan 01, 2011
Display is reading EAAF. What does that mean?
If the internal temp is less than 40 F you will get his code. Warm up the heat sensing probe and it should work just fine. If not here is the contact number: MASTERBUILT Customer Service at 1-800-489-1581
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 19, 2010 | Masterbuilt 20070106 Electric Smoker
I have a masterbuilt 20070106 and it is flashing a code EAAF. What does that mean?
Internal temperature must be above 40 F. Use a hair dryer on the internal thermostat and it will start right up.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
Will not heat
You have a faulty wire or bad heating element, I will bet that it is a wire broken or burned apart. Open the unit and check the wiring from the case to the element and check if it is not severed or burned apart.
Dec 24, 2009 | Masterbuilt ESQ30B Smoker
EAAF Error Code
I went to start my smoker Thanksgiving morning in Denver and I got the EAAF error. I checked all electrical connections and they appeared fine; I next removed the digital control box and stuck it inside my jacket to warm it up (was 15 deg outside) and lit a candle inside the smoker. After 20 min I put everything back together and it worked. Just remember to remove the candle inside the smoker. I plan to call Mastercraft on Monday to see if they can tell me what EAAF means.
Dec 13, 2009 | Masterbuilt 20070106 Electric Smoker
Printout reads eaaf
Hold a warm rag over the end of the thermocouple sticking out of the back, INSIDE the smoker. When the probe gets up to 40F or so the element will turn on and you will be good to go. The computer just doesn't understand whats up when the thermometer gives such a low reading.
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
My smoker reads eaaf on he digital printout
I'm having the exact same problem this morning. It worked a few days ago when I "seasoned" it. I read something about the controller being cold sensitive so I brought it inside to see if that works.
Nov 26, 2009 | Viking Grilling
Masterbuilt 20070106 Electric Smoker Logo
96 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
