Question about Philips Magnavox MRD500VR System
Surround sound tv
I got the surround sound system from a garage sale earlier this year. I am trying to hook it up through the satellite TV box so it can easily transmit sound and video and through the sound system itself.
  • 3 Answers
To help you better, you need to provide the make and model of your surround sound system and your satellite TV box..
Posted on Nov 29, 2013
imadejoolaff
  • 27 Answers
SOURCE: surround sound for my home theater.
Connect your XBox360 to your television as normal. On the back of your TV you need to find the "Audio Out" plugs. Your receiver only has Stereo Input (Red&White cables) for input so your TV has to match that. I don;t know your TV model so I can't make sure you have those outputs, but they should be labeled on the back of your television. This will make everything that plays sound through your TV come through your stereo receiver when you put the receiver on the proper channel.
Posted on Mar 03, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips lx3700d
This HTS can't read opticals
Posted on Mar 20, 2008
SOURCE: No surround sound for TV
great answer
Posted on Mar 22, 2008
SOURCE: NO SOUND
Gordon Brady says - go to the 45 Field Support Squadron Reunion in May 2009 and all your problems will be solved. Contact me at gordon brady at hot mail dot com for details please Kev.
Posted on Jan 08, 2009
srinivasb81
  • 51 Answers
SOURCE: getting surround sound from tv
The only way to get the surround sound by your set up box to your system by audio connections ok other than you cannot get from TV surround sound.
Posted on Jan 09, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Tv surround
It depends on what you currently have as equipment.
You'll have to have something that outputs in digital audio (coaxial or optical). Either your reciever (Cable/Satellite) or the TV. You'll just hook that up to the Surround Sound unit and then just turn on the Surround System when you want surround sound.
You'll have to connect the TV as you would normally with audio cables sicne you'll want stereo sound on the regualr channels.
Nov 22, 2007 | Sanyo DWM-2600 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Philips Magnavox MRD500VR System Logo
168 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
