How do I access the setup menu for on screen. The setup button doesn't seem to work and I can't get a menu on the TV. ...rx-v575
2 Suggested Answers
SOURCE: Yamaha RX-V2600 I can not access my receiver's on
Perform a master reset :
Here's How -->Set the master switch to OFF. Press and hold the Straight (Effect) button behind the front panel, then turn the master switch to ON. This takes you to the advanced Setup Mode. Use the program selector knob to get to User Preset, switch this to RESET. Turn the unit off via the master switch. Next time you power the unit on, all the factory settings should be restored with the exception of system memory and auto setup settings.
Posted on Mar 18, 2011
Yamaha RX-V575 sound issue
try other sound settings first, eg music, stadium, games, all the other sound options. if same results your centre speaker could be gone. or you need to increase the volume of the centre speaker in setting mode. do this first before assuming the speaker is no good. hope this helps
Mar 29, 2014 | Yamaha RX-V575
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
No on-screen display of the unit even if the proper source is selected on the tv. It worked the first days and then it disappeared.
thats needs a technician to follow the voltages and maybe find out if there are damaged components.
Mar 11, 2014 | Yamaha RX-V575
Blinking red light rx-v575
It means the its faulty and it has an intelligent fault detector that helps the equioment to protect on its own, a technician will help you diagnose the fault, check amp module(output ic/transistors)
Feb 03, 2014 | Yamaha RX-V575
Remote doesn't work
I JUST BOUGHT A YAHAMA RX-V575 BL RECEIVER.CAN YOU ADVISE HOW I CAN GET A MANUAL FOR IT?.
Nov 03, 2013 | Yamaha RX-V575
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
14 people viewed this question
 Grubhead
Grubhead
