Question about Dryers
Shocked when touched dryer and window - Dryers
    Sergeant:
  • Dryers Expert
  • 448 Answers
Static charge add ground wire from dryer to electrical box screw or to steel water pipe
Posted on Dec 06, 2013
Been shocked by my dryer and while plugging in my coffee pot
Check the Grounding Circuit in your home. Get a tested at your local hardware that you plug into the wall. You might need to get a electrician or your local electrical company to make sure your not having any Main Service Connection problems that is feeding the electrcity back into your home via the Grounding Circuit. This Grounding Circuit is to keep you from being Shocked by touching your dryer cabinet.
Nov 28, 2013 | Coffee Makers & Espresso Machines
Dryer electrical shock
first thing unplug machine and have electrical outlet checked for proper wiring. This is a safety hazard. you can buy a tool for about $5 to check them.
https://en.wikipedia.org/wiki/Receptacle_tester
if it passes this test then there is a wiring issue in the machine. Were you touching anything else metal when shocked?
if it fails, get a professional electrician to check and repair the wiring. Do NOT use any faulty outlet as they can be dangerous.
Stay Safe.
Jun 14, 2013 | Maytag Dryers
Went from a 4 prong to a 3 and get shocked sometimes.
You need a meter. Unplug the dryer and check for continuity between either of the 2 hot legs and the frame.
Sep 04, 2012 | Kenmore 62602 Electric Dryer
I have a kitchen aid dryer and there is a lil ground cable in the back of the dryer...wat is for?
Hi raider omar8...
That little ground (normally green) wire should be hooked up to a ground in your house...either a water pipe,grounded screw on the receptical, etc.
It keeps you from being shocked if your barefoot and wet while touching the machine.
Please take time to rate me
Jul 18, 2011 | Dryers
I removed the metal plate off my dryer that covers the wires, because they were loose, tried to plug the dryer up and got shocked. Is there any way to repair this?
Hi gmcrae1239...
Your being shocked because you do not have a ground wire hooked to your dryer...
I will send you to a webpage that has drawing of 3 and 4 wire with ground hookups that should solve your problem.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jun 27, 2011 | Roper REX4634KQ Electric Dryer
Dryer won't turn on at all.. There is power to it because it shocked me and the washer runs. Do you have any idea what might be wrong?
Wait a minute, the dryer shocked you? I've seen this happen twice, where I got shocked and the dryer welded itself to the washer. Ok, you may have a electrical issue with house wiring. Or, someone may have wired the dryer cord incorrectly to the dryer. I've seen both. I would address the "shocking" issue and once it's solved it most likely will fix the Dryer operation.
Oct 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer just stopped working. I get shocked when i open the door or touch any metal part of the machine.
Unless the shock is static electricity, you'd best unplug it and call a professional. You have a dangerous problem.
Jim Hart
Jun 14, 2010 | LG Electronics 7.3 Cu. Ft. Front Control...
Dryer makes like small melted black spots on metal buttons
those two stips are the moisture sensors. clean them so the shine again and try another load. Good Luck
Feb 27, 2009 | Kenmore Dryers
LER4634J got ''shocked'' and now won't operate
First, test voltage to be sure your are getting 240v into the machine. Sometimes there are to 120v breakers in the breaker box that have to be reset. Check to be sure yours are fully reset.
Nov 23, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
