Question about Dryers
Dryer gives shocks and only shuts off if door opened
  • 39 Answers
You don't give model/make. I assume you get a shock when you touch the cabinet. I assume, also, that the dryer stops if you turn the timer to OFF. Obviously a line-wire is frayed (not shorted) to the chassis. It could be the 2 wires (+ ground) going to the door switch or 1 of the wires in the harness going from the timer to the motor assembly. Call back with more info.
Posted on Nov 28, 2013
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
My 2001 Alero Driver Door Shocks Me Every Time I Exit the Vehicle
This is usually a sign of an alternator getting bad. It can also have problems with bad ground wires . You can buy anti static rubber wire straps that hang from the back of your car. This grounds everything better and decreases static electricity. It also is good for car sickness. If your alternator is overcharging, you may get a shock, so I would have that checked out first, than a short in ground wires. Hope this helps
Jan 02, 2013 | 2001 Oldsmobile Alero
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer just stopped working. I get shocked when i open the door or touch any metal part of the machine.
Unless the shock is static electricity, you'd best unplug it and call a professional. You have a dangerous problem.
Jim Hart
Jun 14, 2010 | LG Electronics 7.3 Cu. Ft. Front Control...
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing machine - door problem
it sounds like door mechanisim has fallen off.remove the top of washer/dryer and look down the front to where the door catch shuts and see if there is anything attached to it.if not your have to reconnect it.Let me know and ill give ya more details
Sep 03, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
