Question about 2wire HomePortal 1800HG Router (1000400229000)
Gateway 1701hg 2wire wireless driver disappeared
I was on line when my driver disappeared. My 2wire cd isn't working to reinstall the driver from it. I need to download the driver but I can't find it at the 2wire or the gateway site.
Do you know any place where I can download the missing driver and reinsert it into the program?
Tak
One Piece
  • 53 Answers
SOURCE: 2Wire 1701hg gateway- Broadband Access problem
hi! have you used this other identical 2wire modem before? if this other 2wire modem (is it the same 1701hg?) well you may need to configure the settings first. also 1000 series modems usually have 3 lights on it; power, broadband link, and local network. if these 3 lights are on, you may need to access the modem's user interface. assuming that all lights are green, on your computer directly attached to the 2wire, open up any browser, type in gateway.2wire.net. it will give you the network at a glance page. click on run system setup wizard, type in the system password. on the ppp authentication page, please check if it has your username & password (this is the one that you set up on your internet acct w/ your ISP), the next screen will establish a connection. (please tell me if you've got any error messages...)
Posted on Apr 08, 2008
kap990
  • 28 Answers
SOURCE: 2wire 1701 hg
If you want to setup wireless network then......
you need to config your router for wireless network..
for that you need to open router configuration page or either you can run the disc you got with your router..
in that it gives you an option of wireless network..
it will ask you to type in a network name ssid give any name you wish to your network..
it will also ask you to type in a password for network...
choose wpa-psk security and type any secure password in 8to 63 charactersand apply and once it's done...
now if you're on windows xp then click start>then control panel>network connections>then rt click wireless network connections and click view available wireless networks there you'll find your network name ssid in it select it and press connect..it will ask for your 8-63 characters password type in the same press connect it will say connected..
unplug ethernet cable and try opening pages ie..
If you're on vista then click start>connect to>rest is same as above...
Posted on Feb 17, 2008
One Piece
  • 53 Answers
SOURCE: 2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Posted on Apr 14, 2008
SOURCE: 1701hg gateway
you can google your gateway or go to downloadpcdriversupdates.com .
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Posted on Feb 07, 2009
2Wire 1701HG Wireless Modem dead
do one thing just upgrade the latest firmware in that
May 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Install 2wire 1701hg without installation CD
1. pull up browser(ie internet explorer)
2. type 192.168.1.254/setup or http://homeportal/setup in the address field. (click on i forgot my password if you forget it. then if you can't figure out the pw with the hint provided then go click on " i still forgot my password". you can then reset the system password)
3. setup your 2wire 1701 page, double check if key codes are there. it should be 522P-22P4-6262-22AT-F2NV
4. In time zone page, just choose the one then click next.
5. setup connection info page, just make sure the username is your primary email address with your ISP and also the correct password. fill out the username and password and confirm password fields ONLY then click next. And you're DONE!
you just have to wait till it successfully establish a connection.
if you're still having problem after doing that maybe twice or more then i suggest giving your ISP a call. they can also send you the 2wire cd if your ISP supports 2wire modem. AT&T does.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 06, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Nov 04, 2008 | 2wire (1000-400108-001) Router
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Apr 06, 2008 | 2wire 2700HG-B Router (2700HGB)
My 2Wire Gateway modem died
don't even try. the components are far too small. go to pacific geeks dot com and buy a new modem. I got one there for $4.50.
Jan 22, 2008 | 2wire HomePortal 100 Network Adapter
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
Computers & Internet Logo
546 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
