Question about Hoover Vacuums
Does Hoover VHD8144D front load washer 7.0KG have a removable lint filter?
Does this model have a removable lint filter?
2 Suggested Answers
beltronic205
  • 1467 Answers
SOURCE: Replacement part: lint filter located on main frame
If uk try espares.co.uk
Posted on Nov 20, 2009
How do I install filter # 38766-028 on Hoover vacuum Model #U8126-900
Remove the plastic filter cover on the motor cover to remove and replace the filter
Feb 14, 2015 | Hoover Vacuums
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
My Hoover steam vac spin scrub will not suction up the cleaning solution . Why is there no suction?
p{margin-top:0px; margin-bottom:0px;} Hello,
Thank you for your recent e-mail. I am sorry to read about the problem that you are having with your cleaner.
Please make sure your recovery tank and lid are installed correctly and forming proper seals. Make sure that your filter is clean of any debris. Clean the screen in the tank lid. Make sure your nozzle and squeegee (if on your model) are free of dirt/lint/hair and attached in their holsters correctly. Make sure you do not have any clogs in the hose.
To restore suction, please try the following:
*Remove dirty water tank and clean filters- main reason for low suction is dirty filter
*Verify the dirty water tank cap is not missing.
*Verify dirty water tank lid is inserted completely into unit.
*When cleaning, the yellow float inside of dirty water tank should be free moving.
• First remove your clean water tank and unplug the machine
• Remove the dirty water tank lid and push the front panel piece (square plastic sliding piece in the front of tank) down to make sure it is inserted all the way.
• When reattaching the lid, hook the tabs on the front of the lid to the tank first, then click shut in the back. Pull up on the lid firmly, it should not lift at all. If it does, try reattaching as a seal needs to be formed for suction.
• Test to see if suction has been regained.
If these suggestions do not solve your issue please call a service center.
Your cleaner has at least a 6 month warranty for manufacturing defects. This warranty begins from the date of purchase, with the original sales receipt. If you do not have the original sales receipt, the warranty may be verified at the warranty repair center by MFG or serial number.
Please visit www.Hoover.com and click on service center locator for a list of authorized dealers in your area for service and warranty assistance.
Sincerely,
Hoover Customer Service 62
1-800-944-9200
Mon - Fri 8am to 7pm EST
**Please do not reply to this email address. This is for outgoing messages only.**
servlet.imageserver?oid=00da0000000yf5q&esid=018g0000005bxv6
ref:_00DA0Yf5Q._500G0AodT5:ref
Aug 08, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Need to clean lint out of the front cover.
You need to use a Hoover Nozzle Cleanout Tool for the SteamVac
You can find the part by clicking the link. Please give positive feedback.
Cleanout tool Link
http://www.usavacuum.com/Hoover-Nozzle-Cleanout-Tool-SteamVac-p/39514001.htm
Jan 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
It will no longer vacuum up the water, Ive only used it 3 times! We unpluged it and let it set we even cleaned it out....
Hello..Try This: Remove the recovery (dirty water) tank, and then remove the lid. Now reinstall the lid (there are two tabs on the front of the tank, the lid must be installed over those two tabs, and then "rolled" trowards the back., It will "click" then you know it is installed properly. Without the lid on tight, there will be no suction. Also, You can check the lint filter located under the little window. Pry the window off(you may have to use a flat screwdriver) and clean the lint offf of the filter. This also will prevent suction if clogged up. I hope these suggestions help. Please let us know by giving feedback when asked. It helps my ratings! Thank you, Rene(the Vacuum Doctor)
Nov 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I can't figure out how to get all the lint/junk out of my bagless hoover mach 4.
After you remove the cup, remove the foam or hepa filter. Reach up inside, where the cup & filter go and there will probably be a piece with what looks like fins on it. Unlatch this. It is a prefilter, to catch the big stuff that gets past the cup.
Jan 04, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Vacuums Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
