Question about Sony PS-LX250H Turntable
Put a brand new drive belt on my sony PS-LX250H and the sound
And the rotation of the record affecting the sound so it comes out slower than it should. The speed is not running at normal. Any suggestions on how I might make the adjustment under the platter? Thank you for your help. Stephen
    Problem Solver:
  • 5 Answers
If the belt is installed correctly (around the center ring on the underside of the metal platter & around the motor post), try adjusting the SW screw on the underside of the unit that apparently fine-tune adjusts speed. It fixed the speed on my turntable - more info/instructions on it are posted under Mocamom1's question & solutions regarding PS-LX250H speed adjustment.
Posted on Jul 12, 2009
Sony PS-lx250h
Most likely the belt has come off or is worn.
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Jul 02, 2014 | Sony PS-LX250H Turntable
I have a Sony PS-LX250H that was put into storage and moved twice while I was in transit between residences. Since I got to my new place I haven't been able to get it to work at all even after rep
hi
check the belt it might be loose...
elasticity of the belt is ... no more :(
try turning the plate by your hand and see what happens
Good Luck
May 09, 2017 | Sony PS-LX250H Turntable
I NEED TO GET THE BAND BACK ON MY SONY PS-LX250H TURNTABLE. ANY SUGGESTIONS?
hi,
whach the following video for replacing the belt
showing technics also same for any belt drive turntable.
ok
Jan 05, 2011 | Sony PS-LX250H Turntable
I have the sony record player above, and when I was moving I put it on its side and the belt came off. Now I cant figure out how to put it back on. Help ?
The Operating Instructions link on this page:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=PS-LX250H
appears to give guidance on connecting the belt. Any use?
Oct 13, 2010 | Sony PS-LX250H Turntable
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
May 17, 2010 | Sony PS-LX250 Turntable
PS-LX250H
Have you measured the stylus downforce. It usually is between 1 & 1.5 grams.
Apr 21, 2010 | Sony PS-LX250H Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
Sound is dragging when record is playing.
sounds like your drive belt has stretched?
try this company
mailto:info@needledoctor.com
Apr 05, 2009 | Sony PS-LX250H Turntable
Drive belt on Sony turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Sep 07, 2008 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
762 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
