Question about Polaroid A500 Digital Camera
How do I format the sd card on a POLAROID CAMERA A500 DIGITAL CAMERA
Format SD Card
4 Suggested Answers
marked
  • 6487 Answers
SOURCE: I have an a500 Polaroid
Usually this happens when the card is bad so better try a different card for this camera , but after trying a second card and still same problem the firmware of the camera is the one that is bad and needs to be repair.
Posted on Aug 22, 2010
  • 639 Answers
SOURCE: My Polaroid a300 Digital Camera says to make sure
I'm sure you aren't missing something. Have you tried to take a picture and connect your camera to your PC ? if your PC don't have any problem to read and copy the picture, I think you can just ignore the notification.
But if you got any problem, like your PC can't read your data in your camera memory, than this formatting would be necessary. Not via camera of course, but via PC. If you can connect your camera to your PC and the memory card read as removable disc, then you can format it from Windows Explorer. But if you can't, take off the memory card and format it via car reader. And I suggest you to format before you take any pictures because formatting process will erase all of your data inside the memory card.
Hope this help and be kind to rate please.
(^_^)
Posted on Jan 06, 2011
t00nz
  • 4738 Answers
SOURCE: Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Nov 26, 2011
What sd card for i237 polariod
The i237 will work with any SD card up to 2GB in size or any SDHC card up to 32GB in size. It will not work with SDXC cards, 64GB or larger.
Jun 30, 2014 | Polaroid i1237 Digital Camera
Nov 25, 2011 | Polaroid Cameras
Cant take picture. polaroid a500 camera reads sd protected.
It means the sd card cant be accessed unless you remove the protection . Connect sd to laptop and use software to remove the protection .
Mar 13, 2009 | Polaroid A500 Digital Camera
Camera does not recognize memory card
Did you format your memory card before you tried to use it? Format your SD card in the camera first and see if you still have the problem. Also, check to make sure the switch on the card is not in the locked position.
Rob
Feb 22, 2009 | Polaroid M635 Digital Camera
SD Card Locked; Tried formatting SD card still no luck
There will be a small slide switch on the SD card u need to just slide that switch on the Opposite side that then insert it to the camera it will work fine....... Good Luck
Jan 19, 2009 | Polaroid i830 Digital Camera
Lexar Platinum II 4GB sd card won't work on my Polaroid PDC 3070
That card is not compatible with that camera. It's too large for an older model like that. Backup the card's contents and format it. It should work in newer models but probably not the PDC 3070.
Jan 16, 2009 | Samsung Digimax S730 Digital Camera
Polaroid i533
Check you camera instruction book. The card may be the wrong one or two large or???
Jul 26, 2008 | Polaroid I533P Digital Camera
Sd card
Hey litbit3471,
What you most likely need to do is format the SD card. Directions on how to do this are on page 82 of your camera manual. I have included a link to a PDF download of your camera manual incase you need it. I hope this helps!
http://www.polaroid.com/service/userguides/digital/cameras/i830_ug_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 16, 2008 | Polaroid i830 Digital Camera
New POLAROID i735--CARD ERROR
Fresh SD cards must be formatted before being used. Use the camera's menu options to format the card.
May 21, 2008 | Polaroid I533P Digital Camera
Memory cards
Most likely the SD card needs to be formatted. You should be able to have the camera do this, but if not, find a computer with a card reader and format it there.
Hope this helps,
Steve
Oct 09, 2007 | Polaroid i733LP Digital Camera
Polaroid A500 Digital Camera Logo
26 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
