Question about Vizio Televison & Video
Vizio e601i-a3 won't turn on
New vizio e601i-a3 and I have problems. It won't turn on, even after I've plugged it into many outlets.
SOURCE: Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
Posted on Aug 17, 2008
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
SOURCE: Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
Posted on May 12, 2012
jerry_alan_c
SOURCE: Digitalstream LCD HDTV won't turn on
turn on a toggle switch in the back
Posted on Jan 10, 2013
  • 1056 Answers
SOURCE: I have a Vizio e601i-a3 TV , an angry gamer threw
The cost of the screen, and the tools needed to make it work with your current TV would be more expensive than it would be buying another TV. Go find the gamer that caused the damage and get them to buy you a new TV.
Posted on Oct 03, 2013
I have a Vizio E601i-A3 tv that has video problems.
You have a bad tcon board or the panel is bad but this set has some issues with the tcon board...you could try baking it if you wanted, its not going to hurt anything
Apr 02, 2018 | Vizio Televison & Video
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 26, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How to fix no picture on vizio e601i-a3
Try the flashlight test for image in a darkened room. If you see image checkout the inverter board.
Mar 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 07, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My vizio e601i-a3e doesnt come on, no led , checked power and the wall and it is good
Go to you tube type in your question and you should get the video you need to sort out your problem .
Dec 21, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have a Vizio e601i-a3 TV , an angry gamer threw the control and brother the screen. it till turns on ut it looks like shattered glass around the impact spot. I have been searching high and low on google...
Oct 03, 2013 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Open Questions:
Televison & Video Logo
190 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
