Speaker manuals FQ # 81 - Audio Players & Recorders
It can be possible to bi-amp a pair of Klipsch RB-81 with this receiver for stereo listening, and if yes, how...
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:
http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
Oct 14, 2013 | Sony STR-DH510 5.1 Channels Receiver
Modify - open rx/tx for all more FQ
You have an Icom IC-4088SR HH radio, that much I can under stand, But the rest is confusing.
Modify - open rx/tx for all more FQ, is very cryptic, and doesn't make sense.
Please provide more info, the more info you provide the better we understand and the quicker we find a solution for you.
Cheers,
Peter
Aug 25, 2012 | Icom IC-4088SR PMR446 Handheld Transceiver
My tv is blocked and the light is flashing and i can't turn it on. how can i make it work? how to unlock sony kv 28 fq 70 e
Must be on standby,use remote to switch it on or manually press channel buttons up or down. Good luck.
Sep 13, 2011 | Televison & Video
How do i make a LG speaker system MODEL: LHS-D6230T work ??
One way would be to find a manual that supports them and read it.
Web search "LHS-D6230T manual"
http://www.tada-rv.com/scripts/pdfretail/get.php?id=81
Aug 07, 2011 | LG Audio Players & Recorders
Monitor panel
You can download the manual here:
http://www.fitnessquest.com/scripts/cgiip.exe/WService=fq/story.html?article=3079
Mar 05, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
I just need the manual for EDGE 475 upright bike
Your bike is made (or distributed) by Fitness Quest. A check on their web site failed to list a manual for it, however, it does say if your product is not shown that you can call their Customer Service number to get one.
The number is 1-800-321-9236.
Here is the site where this information is found:
http://www.fitnessquest.com/scripts/cgiip.exe/WService=fq/story.html?article=4407
Jan 27, 2009 | Bike Cycling
TI-81 manual
  1. Right click the link below
  2. Click Save-As
  3. Save to Desktop, or other location on your computer
  4. Enjoy
http://education.ti.com/downloads/guidebooks/graphing/81/81$bookeng.pdf
Nov 07, 2008 | Texas Instruments TI-81 Calculator
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here: http://china.giga-byte.com/FileList/Manual/motherboard_manual_7n400pro2_e.pdf
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Mike
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
135 people viewed this question
 Grubhead
Grubhead
