Question about RSQ HD-787 HDD Multi-Format Karaoke Player Open Box
My hd787 hdd not turn on, only red light but nothing else happen
Acer aspire 5111 won't turn on
Common problem is HDD won't come up to speed and needs replacement. Can try unplugging and removing battery, then re-install and try to start. If that fails, need to install new HDD. Hope you have backed-up everything.
Feb 06, 2018 | Computers & Internet
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
When I try to power on the PC the green light will flash but nothing else will happen. I thought it might be the power supply but doesn't that usually give a red light and beeps. Neither of the cooling...
Hi take out everything and disconnect all hdd and cd/DVD try turn it on only with procesor, graphic card and memory ( if you got more then one bone try with one if fail try another). You can also try reset CMOS . Let me know what happend
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
My xbox 360 elite has 1 red flashing light and the screen is all weird whats happening???
hat's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
so first disconnest all wires, wait a couple minutes and plug everything back in and turn it on. if its still red then its a HDD issue. take the HDD out and turn the 360 back on. if it works then you just need a new HDD,.
and if that doesnt work, then its just a system error and youll need a new one.
May 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Green light comes on but nothing else happens. No
try bringing it into a sony store and asking whats wrong with it
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Problem hardrive barracuda 7200.7 160G: the led
I am thinking external HDD?? Bad power supply or check the connection.
Jul 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
RSQ HD-787 HDD Multi-Format Karaoke Player Open Box Logo
Top RSQ Computers & Internet Experts
David Payne
David Payne
Are you a RSQ Computer and Internet Expert? Answer questions, earn points and help others
