Question about KitchenAid Washing Machines
Knocking and burning smell - KitchenAid Washing Machines
    New Friend:
    Problem Solver:
  • 19 Answers
Top Loader?
Possible Motor problem, run with just the water in it NO LOAD.
Burning smell possible motor knocking could be the belt splitting and slapping the inside.
Posted on Nov 29, 2013
Knocking Engine
Pull a plug and check to make sure that you put the correct plugs in. If they were the incorrect heat range you can burn off the electrode and it could have got stuck in the valve, causing the knocking sound. Use a long 3/4 extension as a stethoscope to try and locate which side of the engine the sound is comming from. Then do a compression check to find the cylinder with the stuck valve.
Pull a plug and check to make sure that you put the correct plugs in. If they were the incorrect heat range you can burn off the electrode and it could have got stuck in the valve, causing the knocking sound. Use a long 3/4 extension as a stethoscope to try and locate which side of the engine the sound is coming from. Then do a compression check to find the cylinder with the stuck valve.
Jan 14, 2014 | 2002 Ford Explorer
I have a 2000 volkswangen jetta vr6 and it has a knocking sound in the top engine need to know if changeing the oil will fix the problem oil look realy thin and smells like gas.
If your oil smells like petrol (gas) this is a big problem. Drain the oil and replace it and the filter. I would take a sample of the oil to a mechanic just to get his opinion. Gas getting into the oil on a modern car (fuel injected) is less common then just burning oil but has been known to happen. Knocking sound is usually crank shaft damage which is not a good prognosis. It is likely if fuel is in there now it will get in there again - Your best chances are to use as heavy weight semi-synthetic oil you can get with the aim that the oil pressure will mean you burn oil in preference to fuel pressure pushing its way into your sump.
Jan 18, 2013 | Cars & Trucks
Mazda 626 2002 smells like burning rubber
This is not good. Sounds like the heater fan bearing and/or resistor is burning out. Not familiar with your heater fan location, but most will be removeable from engine compartment.
Just remove it and spin it by hand or hook auxillary power to it to test. Some autoparts stores can test it for you. Stuff a rag in the opening to block fumes if this must be driven for parts run.
Jan 27, 2012 | 1999 Mazda 626
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Burning oil smell after short drive beneath car under driver. No leaks or panel lights showing. Entermitten knock sound between radio panel and auto stick shift. Vehicle runs good. Noise started last week.
OIL BURNING SMELL PROBABLY COMING FROM THE EXHAUST AT TAIL PIPE WHERE CAR BURNING OIL.KNOCK NOISE AT RADIO AND TRANSMISSION SHIFT STICK COULD BE STICK SHIFT LEVER MOUNTING BOLTS COULD BE LOOSE OR SHIFT LEVER BROKEN.
Sep 21, 2010 | 1997 Toyota Avalon
Check engine light, knocking? PCV Valve?
I have this same vehicle. The "check engine" light warns you that the input from a sensor is not valid. To locate the problem sensor you need to have the fault codes downloaded and interpreted. I am sure your PCV has little to do with this. The burning smell cold be oil from your transaxle seals being thrown up onto the exhaust pipes. The outback is a sophistecated and refined vehicle that requires sophisticated equipment to work on it. If you have engine "knocking" it is likely to be the knock sensor and if this is the case, you need to have it remedied very quickly
Mar 22, 2010 | 2000 Subaru Outback
The engine is making a really loud knocking noise and the oil light is on. it also smells like something is burning or running hot
Doesn't sound good. Check oil level. Also check for metal in the oil once you pull the dipstick. A loud knocking noise is a sign of a blown engine may be you spun a rod in which case you would need engine replacement or rebuild
Oct 23, 2009 | 2001 Dodge Stratus
Clicking/knocking sound and feel when shifting & smell
first check the clutch hydrolic fluid. If it's low or leaking, it may not disengage the clutch completely causing the disk to drag (and smell) The knocking sounds like you're loosing the thowout bearing and/or possibly the disk (there are cushion springs that may have come out of place). Take it to a transmission shop that does free diagnosis. anything other than fluid-related is going to be pricey.
dont forget to rate ... and dont shoot the messenger
Jan 03, 2009 | 1999 Volkswagen Beetle
Oil light comes on and the engine begins to make a knocking sound
how much oil is left in the engine ?
the smoke was probaly oil burning,the knocking could be from low oil pressure,this could be very bad.check the oil and coolant levels and repost and let me know how they are.if any oil shows on the dipstick smell it and see if it smells burnt.
Nov 15, 2008 | 2005 Toyota Corolla
Washing Machines Logo
18 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
