Question about GE Add-On Wireless Digital Color Camera 45256
Pairing with I pad
Bluetooth to iPad or phone
    Top Expert:
  • GE Master
  • 6,702 Answers
You can't use bluetooth to pair other camera's or any other equipment with the iPad, unless it is approved with Apple. To view pictures from my DSLR, I use a Transcend WiFi card (Eye-fi and other brands have them to on WiFi) with a special app. But still this is on WiFi. The card works as a hotspot. For bluetooth you need special equipment. The manufacturer has to build in special protocols which he gets from Apple.
Posted on Nov 30, 2013
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
I forgot how to connect my DG Bluetooth Keyboard Case to my iPad. Can you help please?
It should be just like pairing an audio Bluetooth device. Turn the iPad's Bluetooth on and the keyboard as well, the iPad will look for an available device, it should pop up in the iPad, tap it to pair, if its ask for a pairing number, it should be noted in the box that came with the keyboard or in the instructions, that should be it.
Mar 10, 2015 | Computers & Internet
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
Pairing with Bluetooth keyboards.
does yours have bluetooth set to acquire might be the problem I know some older systems do not work with blue tootth
Oct 31, 2014 | Alcatel One Touch Pop S7
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Bluetooth keyboard will not connect
I'm assuming Bluetooth is turned on on the ipad.
follow the keyboard instructions to put it in pairing mode.
Then in ipad settings - Bluetooth you may need to select the keyboard.
Feb 26, 2014 | Apple iPad Mini
Ipad and beikin keyboard
You will need to enable bluetooth on your iPad and then pair the keyboard to the iPad. Try the following:
  • On your iPad, tap the settings icon from the Home Screen.
  • Tap on General.
  • Tap on Bluetooth.
  • Toggle Bluetooth to On
  • Turn on the Belkin keyboard.
  • The keyboard will show up under Devices on the iPad.
    Select Belkin Bluetooth Keyboard.
  • A code will appear on the screen.
    Enter this code on the keyboard and click Enter.
A message will pop up when pairing is successful. If pairing fails, repeat the steps above. If you're still unable to pair the two leave a comment and I will help further troubleshoot.
Hope that helps!
Jan 15, 2014 | YouTube Videos
Ipad and Samsung Bluetooth pairing problems
I have had the same problem it's doing my head in so frustrating they will pair up but can't see each other even if right near have you found a solution?
Nov 16, 2012 | Samsung Galaxy S GTI9000 Smartphone
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
GE Add-On Wireless Digital Color Camera 45256 Logo
137 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
