Question about Frigidaire Refrigerators
Refrigerator will turn on if i unplug it and plug it back it but it shuts off after a few minutes
Refrigerator is warm. if i unplug it and plug back in it will run for a few minutes but then it shuts off again. i have to unplug it to get it to turn on
  • Frigidaire Master
  • 842 Answers
I have heard of this problem, I have found that the sensor near the ice maker is causing this issue. I can only assume you have a newer model because you didn't leave or insert a model number with your inquiry. I am willing to research this if I can get more information from you if you would like. Get back to me and I would be glad to help.
Thanks
Posted on Nov 28, 2013
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
  • 92 Answers
SOURCE: LG refrigerator isn't cold but bottom freezer is freezing the food
ff is fresh food may be the ff thermisor but i would first check the freezer back wall is it frosted up can you hear the fan in the freezer blowing the air up to the ff section
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
  • 4 Answers
SOURCE: Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech.
Posted on Aug 15, 2008
Sea Breeze
  • 4654 Answers
SOURCE: blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Posted on Jul 18, 2009
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
No cool what problem?
There could be a few problems. Is there any hum when you unplug it and plug back in after 10 minutes? Can you hear a fan going when it is plugged in and/or a small noise indicating the compressor is running? Are the coils in the back warm on the outside of the unit? Give me a few more details on noises if there are any. Thanks for using FixYa.
Jan 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
This frigidaire (side by side) only blows warm air on both sides
Good day,
First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
Sounds more like starting components on the compressor, or a compressor starting to fail.
Post back with results.
Thank you.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Fridge and freezer are warm, i can hear a fan running, and i think what sounds like the condenser turning on, theres a click followed by a hum for a few seconds then it shuts off. It repeats this every 30...
at the back of your refrigerator, you will see the motor compressor below, at the side body of the compressor you'll find a small box attached to the body where the wires come in, take out the cover, before doing that, unplug it first. then take the cover out. now plug it, don't touch it.
see if you can hear any click sound then it will shut off. if yes unplug it and take out the overload relay attached to the compressor where the wires are connected. try to replace it, just remeber the wire matching.
Nov 05, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
I have a MBF2556HEW Fridge. Various fresh & liquid items in my fridge are freezing. I've turned the temp down to 3 from 6, and it's still doing it. The fridge also makes a clicking sound every few...
Try unplugging fridge for a few minutes then plug back in,if it still does it you could have a relay going out? Also if you have another freezer put frozen items in it and refrigerated items in another fridge unplug othernight then plug back it it could be froze up also when unplugged clean coils with brush and vaccum either underneath or on back,most likely underneath(becarful not to bend anything and make sur unplugged)Try all these tactics before you start changing parts!!!!Best of Luck to You!!!amtnng
Aug 12, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer won't shut itself off
turn the temp up a bit and see if it shuts off if not it needs to be repaired,hope this helps ya
Cheers
Johnthetr870
May 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
