Videocon vna 811
Videocon top loading washing machine filling all going out, how to stop this?
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 90 Answers
SOURCE: washing machine
check pressure switch hose
Posted on Jan 06, 2008
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
e-Guru
  • 3917 Answers
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 02, 2011
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Whirlpool Cabrio washer will not fill with water?
LF is a long fill the machine control has not detected a change in the contact of the pressure switch which controls water fill and stop you didn't mention top load or front load, on a top load or front make sure you have water going to machine if you have flood safe hoses to machine replace then with regular washing machine hose the design of these hose will stop water flow, crazy as this may sound make sure the drain hose has not fallen onto the floor water fills and runs right back out, as a tech I have not had a pressure switch go bad usually on a front load the clip that holds the black hose in place pops loose allowing the hose to rub against the rotor which turns and rub a hose in it sorry to be long winded two simple checks make sure you have water to machine and that the black hose from the pressure switch to the tub does not have a hole in it
Sep 01, 2014 | Whirlpool Washing Machines
Videocon washing machine model V NA-811 fully automatic body is rusted i would like to have a new body . where can i get it please inform me
Hi I have a Videocon V NA 811, don't know where to put the detergent and what is that small compartment with a net for
Nov 20, 2011 | Washing Machines
Washer filled up to do load and then stop will not wash or spin, but will fill up for a bigger load??
you need to replace the door switch , when the switch is shorted or open it will only fill up and not go any further
Sep 26, 2011 | Roper RTW4300SQ Top Load Washer
My maytag home top loading washing machine over fills with water, ie. the switch to stop filling and start washing doesn't go off. I can drain it by setting it to spin.
top loading machines comes with a pressire switch to determine the water level.IT will fill with water till the switch is triggered to stop filling and continue with the next task of washing. there would be a rubber hose connected from the wash bucket to the pressure switch. Check for broken,leaking,bitten by rats hose or probably the switch it self is faulty, which is rather rare.
Aug 24, 2011 | Washing Machines
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Nov 18, 2008 | KitchenAid KAWS750L Top Load Washer
Kenmore top loading washing machine
For a top load machine, check if the screws are tight on the hinges for the lid. Some models these will come loose and cause intermitent functionality. You may also have the contacts in your timer going bad. This will cause your machine to "lock up" intermitently.
Jun 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
