Trying to access code - Computers & Internet
I forgot my viber access code . i got automatic call from viber to get an access code. i did not get SMS. Now i need to enter my viber access code again. how can i know my code? now i can't access
This is an official representative of Viber.
Please try removing Viber, wait 24 hours, reinstall and try again (make sure you try both the SMS and the automated call options).
In addition, you may try to register to Viber with a different number (for example - your home landline number, a friend's number, etc.), in order to determine whether the problem is specific with your number, or a general one.
If this doesn't help, contact our support team at http://support.viber.com and give them the details of the problem.
Oct 15, 2012 | Samsung Cell Phones
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
What if access code is forgotten?
Try using NokiaFREE Unlock Codes Calculator v3.10. Works brilliant.
Jul 27, 2009 | Nokia Cell Phones
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 | Cell Phones
WRONG ACCESS CODE
default access code is 0000 or 00000. Please try both.
Feb 20, 2009 | Sony Ericsson G900 Smartphone
"Lost" modem access code
This site may work for You:
http://www.softwaredriverdownload.com/download_siemens_speedstream_41004200_dsl_modem_manual.html
looks like a manual install of the driver packet. but it's FREE! Good Luck
Feb 19, 2009 | Computers & Internet
Computer Access Code
To create a new access code
  1. Go to the host PC whose access code you would like to change.
  2. Make sure that the GoToMyPC service is running (look for icon_white2.gif icon in the system tray).
  3. Right-click on the icon_white2.gif icon in the system tray and select Change Access Code.
  4. Click the Forgot it? link.
  5. Enter your email address and account Password.
  6. On the New Access Code dialog box, enter your new access code, confirm the new access code and click OK.
Note: You will need to be at the host PC to perform this function because you will not be able to log in to your host PC without knowing the Access Code for that PC.
Thats if you want to change the access code but if you are simply looking for your access code you need to get in touch with your group.
Code Access Security is a new concept brought in by the .NET framework. Code access security essentially involves granting permissions to an assembly. Code access security uses the location of assembly and other information about the identity of code as a primary factor in determining permissions to be granted to the assembly. This information about the identity of an assembly is called evidence.
Once loaded in runtime, the code starts executing in the restricted environment depending upon permissions granted to it. If the code is not trusted enough to run or runs but performs an action for which it has no permissions, then a security exception is thrown.
The code access security system means we can stop running of malicious code and also restrict the code to run in a restricted environment where we are sure that it won’t do any damage to the resources. Let us now see few cases where code access security becomes
crucial.
Suppose an organisation is working with some extremely important data, we would use a code access security system to state which code is allowed to access the database and which is not. Similarly if we run an application from a network drive and it tries to access the file on a local drive an exception must be thrown. This can be done using a code access security system.
It is important to know that code access security protects resources like local disk, network, user interface from malicious code. It is not a tool for protecting software from users.
Code access security works on the basis of Code Groups and Permissions.
Dec 05, 2008 | X2 Systemax NO OS AMD Desktop Computer -...
Access code for 02 multimedia message
Hi
Try "00000000" (eight zeros) this is the original factory code, If this doesnt work do a factory reset in settings (#9) this should reset all passwords/codes back to "00000000" then try again, Hope this helps.
Nov 12, 2008 | Samsung SGH-t629 Cellular Phone
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Jun 01, 2008 | Efficient Networks SpeedStream 5100 Modem
Trying to access online play
how you connecting to the web have you tried here for set up issues http://us.playstation.com/PS2/Online
riz.
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
