Question about Casio Office Equipment & Supplies
I have graphing calculator casio fx-9750G2. my problem is when I try to graph a line it keep saying Argument ERROR Press: [EXIT] and I can't graph please please please if someone now how to solve my problem please help me.
  • k24674 Nov 28, 2013
    Hi Akram Sitawi, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What type of graph are you using? Function, parametric, polar, sequential? What function are you trying to graph? What independent variable are you using X, T, Theta, n? How are you entering your expressions?
  • 8068 Answers
SOURCE: my calculator will not graph
Clear the old contents of variables .
Press [2nd][MEM][2:Mem Mngt/Del][6:Y-Vars][ENTER]. The graph functions that have been defined are listed on screen. Scroll to select the one you want to use and press [DEL].
There is amore radical way to clear the memory:
Press [2nd][MEM][7:Reset] [1:All RAM][2:Reset][ENTER].
Hope it helps.
Posted on Oct 02, 2009
  • 8068 Answers
SOURCE: i cant get to the standard window on my graphing calculator
I am not sure I understand but if you are talking about the ZoomStandard graph window, you access the configuration as follows. Press MENU, Scroll to highlight the [RUN] icon and press [EXE].
Press [SHIFT] [F3:V-Window]. At the bottom of the screen you have the different options . Press [F3:STD].
Hope it helps.
Posted on Oct 03, 2009
  • 8068 Answers
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Posted on Oct 11, 2009
Testimonial: "Thank you so much!!!"
  • 8068 Answers
SOURCE: graphing syntax error
To draw graphs.
  1. Turn calculator ON (isn't that obvious?)
  2. If you see no icons, press [MENU]
  3. Use arrow to move focus on GRAPH and press [EXE]
  4. By default, the graph type is Y=
  5. Enter your equation on line Y1=, use the [X,theta,T] key to enter the X-variable
  6. Press [EXE] when finished entering a function.
  7. Enter other functions if you want.
  8. When done, press [F6:Draw].
  9. If you do not see a big portion of the curve you can press [SHIFT] [F2:Zoom] and select [F5:Auto]
I am enclosing screen captures. The screens you see may not look exactly as on the FX-9750G, but all menu commands you have to execute are accessed by the same key sequences.
This last one is obtained with the Zoom: Auto
Posted on Mar 02, 2010
  • 8068 Answers
SOURCE: im trying to graph a
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Posted on Jul 26, 2011
Testimonial: "thank you for your help sooo much u are a life saver and i was able to figure out how 2 graph the equations on my calculator"
When I try to graph it says argument error
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
Mar 16, 2015 | Casio FX-9750GII Graphing Calculator
Graphing calculator argument error
The function you give as example in the additional information to your duplicate post is too simple to generate an Argument error. Maybe a syntax error but not an argument error.
Check what you enter on the line that defines the function. Do not confuse the minus sign - (for subtraction) and the change sign (negation sign) marked (-).
You can also reset your calculator by pressing the button on the back.
Mar 09, 2014 | Office Equipment & Supplies
How do I graph sinx on my Casio fx-9750GII calculator?
Turn calculator ON
If you see no icons, press Menu
Press 3 (Graph) draw your function. (more on that later).
If the first line of the display show Graph Func : Y= you should be able to draw your function.
If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=.
After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw.
Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Feb 21, 2013 | Casio CE CASI FX-9750GII-L-IH GRAPHING...
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
When i am graphing and I enter- Y1=Sin(theta) it does not graph it and says syntax error
When drawing function graphs of type Y1=, the name of the independent variable should be X
For polar graphs r=.., the independent variable is theta, while for parametric graphs it is T
To enter the default independent variable, press the key marked [X,Theta, T] . It will type in the correct name.
Sep 18, 2011 | Casio FX-9750GPlus Calculator
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a...
Jul 26, 2011 | Casio FX-9750GPlus Calculator
I am using a casio graphing calculator and I am trying to graph a parametric function. I put the mode on Param and I inserted xt and yt and i press draw. It draw but then stops and gives me an arugment...
The argument error must have something to do with the parametric functions you are drawing. I do not think anybody would know where to look unless you give us the functions.
As to the range of the T-variable, you can set it by pressing [SHIFT][F3] to open the (V-Window) configuration screen. It starts showing Xmin, Xmax. etc. To get to the T range, use down arrow (about 7 times).
Dec 06, 2010 | Casio FX-9750GPlus Calculator
Graphing syntax error
To draw graphs.
Mar 01, 2010 | Casio FX-9750GPlus Calculator
66 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
