Question about Microwave Ovens
How do i use thye defrost - Microwave Ovens
  • 7,993 Answers
You read the weight of the food on package (in lbs)
Put the food on a microwave safe plate /container.
Close the door.
Press the Defrost by weight button
Enter the weight of the food. The time will be set automatically.
If you have a defrost by time, just decide on the time duration and enter it
Posted on Nov 29, 2013
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
How do you defrost on the microwave
What is need to set the program, select defrost function then select the weight of the food to be defrosted and push the value of the weight. Now select the heat value and press start as the processor will then decide the time to defrost.
This is a simple program setting or else you can choose a preset heating defroster program.
Aug 19, 2011 | Microwave Ovens
I plugged in the new microwave, model JVM1740DP1CC, and nothing happened, is there a fuse inside the mivcrowave and where is it located
Hello there and thank you for choosing fixya
Yes these microwaves al have a small inline fuse in them and thye a re located on the controle board you need ot remove the outer cover and then the fuse will be seen on the right side towards the front as you are looking at it it is a small fuse that simply pulls off and a new one snaps back in place
Walmart or radio shack will have theese also any automotive parts store will carry them too ok
Hope this helps.
Best regards MIke
Jul 25, 2011 | GE Spacemaker JVM1740 Microwave Oven
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Build-up of soft ice all over in the freezer
Do a manual defrost of the unit. Unplug it.. empty the freezer and place a fan b l o w i n g into the freezer for about 2 hours.
After the manual defrost return the unit to normal service.
If the soft build up of ice shows up again take a very hard look at the door seals. Look for tears.. gaps or any place the gasket is no longer attached to door face
This unit should defrost about every 10 hours. If it does not automatically defrost,,,, doing a manual defrost will only keep the unit going if you repeat the manual defrosting drill every 2 - 3 days.
If it just never goes into the automatic defrost cycle at all, the control board could have failed. PN: W10116216
Item 5 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KFCS22EVMS3/0593/0161000/W1003150/00003?blt=06&prst=&shdMod=
A failed defrost heating element can also cause this. Item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-number/Kitchenaid-Parts/Refrigerator-Parts/12729129/0046/106/Model-KFCS22EVMS3/0593/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=KFCS22EVMS3&subCompDesc=Unit%20parts&brandDesc=KITCHENAID&modelDesc=REFRIGERATOR&pathTaken=partSearch&blt=11
Nov 18, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
When defrost kicks on in the freezer it stays on to long and defrost the food.
The defrost timer/control board is not working right... replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 25, 2010 | Microwave Ovens
Turntable, fan, and bottom lights are not working, but microwave itself works. Is there a fuse that is common to these 3 items, and if so what kind is it and how do you get at it? - Thanks !
open up thye case and carefully discharge the h.v. capacitor after unplugging unit,there is only 1 fuse and unit wont run at all if this fuse is bad,then wiggle all the wire harness connections at all connection points,it sounds like a bad connection only
Mar 12, 2010 | GE JVM1440 Microwave Oven
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Microwave Ovens
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
