Question about Car Audio & Video
My 15 inch Kicker CVR had a light rattle or vibration to it, what about 15 minutes later it just stop playing its not froze everything hooked up correctly what is wrong or how can I fix it?
    Top Expert:
  • Car Audio & ... Master
  • 43,901 Answers
The rattle could have been the voice coil deteriorating so it may be necessary to have your Kicker rebuilt or replaced.
Posted on Nov 28, 2013
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: how to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Posted on Dec 24, 2008
etirbynnor
  • 655 Answers
SOURCE: how do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Posted on Nov 11, 2009
pctech1
  • 1940 Answers
SOURCE: how you hook up 15
Here are a few wiring diagrams to get your started.
Posted on Oct 01, 2010
There was a slight vibration to my 15" CVR kickers.. about 15 minutes later it completely stopped working, it's not frozen how about do I go about fixing it?
push down on the middle of the speaker ,does it make a scraping sound, if so that means u fried your voice coil ,meaning if to much power goes into the speaker with being able to keep it cool it heats up so much that it cuts the coil and sometimes the pole that the coil is wrapped on right in half hope this isnt the case but thats what it sounds like....
Nov 28, 2013 | Car Audio & Video
What amp should i use for 2 15-inch cvr
goto www.kicker.com you can use there recommended amp to subwoofer guide to get you answer. however i would say use the zx1500.1 amp since it has a 1500 watt rating which about the same as you subwoofers.
Jan 29, 2011 | Kicker Car Audio & Video
How you hook up 15 inch kicker cvr show diagram please
Oct 01, 2010 | Kicker Car Audio & Video
I have a 15 cvr how do i hook it up to a plnet
If it has only one set of terminals on the sub just plug and play- if it has dual coils wire them in parallel(+ to+ and - to -) and wire them to the amp
Feb 12, 2010 | Kicker CVR12 Car Subwoofer
I have a brand new L7 is it blown?
check to make sure your box is securely sealed and that the box itself is not rattling. if not, most subs require a break in period where they can not be played full gain/full volume for the first 48 or so hours... did you break in your subs by paying it softly the first day and slowly turning your amps gain and receivers volume up the next couple of days. if not, it is likely blown
Oct 07, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
How to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Dec 23, 2008 | Kicker CVR12 Car Subwoofer
How do i hook up the speakers
connect each dual in series then parallel each sub
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Need to know how to wire 2 15 inch cvr to a zx1000.1 amp at 2 ohms
If they are 4 ohm single voice coil subs, just connect all the negatives together and then all the positives together. If they are DUAL vc's then need more info.
Aug 04, 2008 | Kicker Car Audio & Video
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
