Question about Roland Music
Low keys stopped working rd600
The first 8 low keys stopped working.all of the other keys and effects and other settings seem to be working. is there a common problem that might point to a soloution if only the first octave has stopped working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Been years since I had an RD600 but I do remember it happened to me once or twice.
It was either the SPLIT function...with one of the volume sliders down, or MIDI channel. Sorry not much of a solution...hopefully this will jog your memory into experimenting with some of the RD's functions: split/transpose/MIDI etc
Posted on Dec 01, 2013
Sir, have a Yamaha PSR 330, very recently the left speaker is not working. Do guide me for the same.
If it was playing fine and just stopped working while you were playing it, it's possible the speaker has failed, or a wire has come off. It is likely something you cannot fix yourself, and should find a local music store, like Guitar Center, who can repair it for you. It's generally not a very expensive repair at all.
If the sound stopped working from one side after you were playing with some controls or editing some voices, you may have set the panning all the way to the right, which would cause no sound to come out of the left speaker. In that case, you would simply need to set the panning to the center again while in editing mode.
If you are not too familiar with the editing features on the PRS 330, and not sure how to set the panning to the center again, you could always simply reset the unit to it's factory settings once again, while will return all the voices, effects, panning, etc. back to like the unit was when it was first taken out of the box and turned on. Here's the process to reset the Yamaha PRS 330 back to it's original settings -
Restoring the default (factory-programmed) settings While holding the C7 key (right-most key on the keyboard), press the power switch to turn the power on.
This operation erases backup data in this instrument (including backup settings in the Function mode) and
restores the factory default settings. The User Songs and the external Songs stored to internal memory will be
retained
None of that works and you do need to have someone look at the unit, here is a link to the Yamaha Authorized Service Locator to find the nearest authorized service center near you -
Servicer Locator
Sep 19, 2017 | Yamaha Music
I imported a behringer SX3242FX today and it was working fine for about an hour suddenly I felt the digital effect that I selected( Delay ) has lost from the microphones and voices became dry.. Then I...
Is the number on the effects display still flashing? Can you select effects or is that section dead now? I've had occasions with my Behringer mixers where a bad ground or otherwise improper power supply seems to cause issues with the effects section but the board seems otherwise functional. It has definitely had me scratching my head a few times and is worth investigating.
Aug 17, 2012 | Behringer Sx3242fx Eurodesk 32-channel...
I have a behringer eurorack ub1204fx hooked up to a bose L1. I can't seem to get the reverb to work
you have to set three gain controls to pass the FX into the mix. The FX send gain for each input channel, the FX fader which sends the FX mix to the effects unit, and finaly the gain that sends the FX output to the mix. Depending on which effect you choose, some are very subtle.
Aug 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
My Voodoo Lab Super Fuzz stop working. The led doesnt light, and the effect sound doesnt work, but the bypass signal is unaffected... I opened it, and test the resistences they seem to be OK... I don't...
If you are using battery, replace it. If you are not using battery, check your pqwer adapter. Internally, the pwer connectors and soldering around it are chronic problem,
Feb 19, 2011 | Voodoo Lab Super Fuzz Guitar Pedal...
HELLO, I HAVE A BEHRINGER PMP 3000 MIXER, AND I CANT SEEM TO GET THE FX TO WORK EVEN THOUGH I FOLLOWED THE INSTRUCTIONS IN MANUAL, IME JUST WONDERING IF THERE IS SOMETHING IME OVERLOOKING? SCINCE I KNOW...
Do the following:
Set each of the FX mix knobs to 12 o'clock (halfway up to start)... I believe they are orange tops for each channel effects are desired for.
Next select the number of effect by rotating the selection knob. The display will flash.
Push DOWN on the selection knob to activate the selected effect number... the display will cease to flash. Note that you can mute the effects with a small button in the effect area and decimal point will come on showing effect, even though selected, is disabled. That small button can toggle the effects on and off.
Next, adjust the "FX to main knob" above the MAIN fader... set it to 12 o'clock to start with.
Note that there are two others that send the resultant same effect to stage monitors if used...
Now ADVANCE the FX (orange) fader to increase the input to the FX. You should start to hear the effects... SOME of the effects are subtle, so maybe choose a long delay one to get the hang of it... choose #3 for example...
The manual is NOT too clear how to use the effects and is confusing... they assume you have knowledge common to mixers... and new users don't.
I would recommend watching several YouTube videos about mixer setup... there are some good ones there !!! Most mixers have a lot in common and once you learn what is there, you can work most any of them... some of the new digital ones are a bit more confusing.
Feb 14, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How to send effects to microphones
You CAN'T send ANYTHING to microphones since they are INPUT devices.
If you want apply effects to the audio coming FROM them then this is what you do:
Adjust the trim and faders for normal use and verify the mics are working.
NOW for those mics you want to put effects on, turn the knob labled "FX" above EACH mic FADER that you want effects on... it will be the orange topped ones... about the fourth one up ablve the PAN and the two MON knobs. Adjust these to send each mic into the effects mixing buss. Start by setting them at 12 o'clock. You will use these to proportion the amount of effects applied to individual mics.
Next, advance the FX fader/slider to around the Unity mark... this controls the amount of the FX mix buss goes into the FX processor.
Next adjust the knob above the MAIN fader that says FX to Main. This controls the amount of the FX that is sent into the MAIN mix buss...
We are almost there... Select the effect you want with the effect knob to the number of the effect you want... it will be blinking AFTER a change... the effect will NOT have changed yet... WHEN you want the effect to take effect, PRESS DOWN on the effect knob and the effect number will stop blinking and you now have the effects on those mics... ADJUST the three level things... the knbs under each channel to proportion between the mics... adjust the FX fader for the USUAL control of effect amount... and finally the FX to main knb to set the limit of the effect going to the MAINS.
Feb 13, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a new kaoss kp and when I put headphones in there is no sound. I dont have a cable to plug it in to the computor. Is there something I have to do to the settings or is it simply not working? Cheers
The Mini KP is an effect processor primarily. Sound passes in and through either with or without processing and effecting. Due to this fact you must have an incoming signal to process, or you wont hear anything. However there are a few settings that act more like a synth and tone generator.To initiate an effect you must touch the pad and hold contact. There is a hold button on the lower left side facing down. If you hit this button while an effect is being created, then you can let go without the effect stopping. You can adjust the effect in real time as well. Out of the 99 presets if you have tried them all with absolutely no sound output, then the problem is physical and will need a repair man/woman.
Dec 12, 2010 | Korg Mini Kp Kaoss Pad
Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
May 28, 2009 | Korg Mini Kp Kaoss Pad
Music Logo
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
