Question about Zynga Texas HoldEm Poker
Loader masage java script 2 - Zynga Texas HoldEm Poker
How do I go about downloading java script?
Java script is native to all browsers. You may have it disabled. You will have to go into your browsers settings and enable java script within your browser. If you have any plugins such as "No Script" then you will need to disable them or uninstall them for Java script to work properly again.
If you meant to ask how to download Java (it is different than java script) then you would visit http://www.java.com and download the software and install.
Seeing as you posted this as a Facebook problem I would be satisfied to say that your problem is java script is disabled in your browser settings.
Nov 07, 2011 | Facebook Social Network
How can i activate my java script i cant' register to yahoo mail it always says my javascript is enabled
Since you haven't mention your web browser please try the following steps
1. Open TOOLS -> OPTIONS -> CONTENT, click on "ENABLE/DISABLE JAVASCRIPT".
1- If your browser is Internet Explorer do the following
2- Open TOOLS > INTERNET OPTIONS >> SECURITY. In security click "CUSTOM LEVEL" -> enable active scripting in the scripting section.
1 - If your browser is Safari
2 - Open SETTINGS>click PREFERENCES>>click SECURITY>>Uncheck ENABLE JAVA and ENABLE JAVASCRIPT
Sep 08, 2011 | Computers & Internet
My masages at yahoo doesent appear at box window
Yahoo! discovered that this error occurs on systems that do not have the latest browser and scripting components provided through Microsoft software updates.
To resolve this issue, please make sure you have the following applications installed:
Sun Microsystems Java. http://www.java.com/en/
Adobe Flash Player version 9 or greater. http://www.adobe.com/go/getflashplayer
Adobe Shock-wave Player. http://www.adobe.com/shockwave/download
Windows Scripting Package. --http://www.microsoft.com/downloads/en/re...
Look for "Windows Script 5.7" for your Operating System and follow the instructions for installing this file.
Internet Explorer 8
You should also visit Windows Update http://www.windowsupdate.com , a Microsoft site that checks your computer for updates and patches to correct related to your operating system and web browser components.
Mar 29, 2011 | Yahoo Messenger
I can't see the messages I send and messages I receive on the chat box using yahoo messenger
hello
Solution 1
Open internet explorer
To enable scripting:
Click the "Tools" menu on your Internet Explorer toolbar and select "Internet Options."
Click the "Security" tab.
Click the Internet (globe) icon and click the "Custom Level" button.
Scroll down to "Scripting."
Enable the following:
* Active scripting
* Allow paste operations via script
* Scripting of Java applets are all enabled
Click the OK button at the bottom of the window.
Solution 2
1. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
2. Type in appwiz.cpl and click OK. This opens "Add or Remove Programs."
3. Select Java and then click the Uninstall button. There may be multiple installed versions, so be sure to remove all of them.
4. Next, download and install the latest version of Java Runtime Environment
5. To ensure the update is effective please Clear the Yahoo! Messenger Cache
6. Restart Messenger to determine if the issue is resolved.
thanks
Mar 08, 2011 | Yahoo Messenger
I cant see my chat messages
You may not have Internet Explorer as your default browser but it still plays an important part in the operation of Yahoo Messenger. It sits as a link between your browser and Yahoo Messenger.
For this reasson you must keep it up to date and the support software for IE as well.
Keep your software up to date by using an update checker
http://www.filehippo.com/updatechecker/
Start with IE and then any support software for Yahoo Messenger - Flashplayer - Shockwaveplayer - Java etc.
Cross check by visiting the Yahoo Messenger Scripting Help page
http://help.yahoo.com/l/us/yahoo/messeng...
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
You will have 2 versions if you have 2 browsers so be careful not to delete them.
Start / control panel / programs
delete any old versions
To enable scripting:Internet Explorer8
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 25, 2010 | Yahoo Messenger
Yahoo script errors
try to re install ym installer or else run malware bytes,
Apr 08, 2010 | Yahoo Messenger
Enablin javq scriptcan't figure out how to get it to work
To enable JAVA:
Internet explorer 6:
1. Select Tools from the top menu
2. Choose Internet Options
3. Click on the Security tab.
4. Click on Custom Level.
5. Scroll down until you see section labeled Scripting.
6. Under Active Scripting, select Enable.
7. Click OK to save changes.
8. Close and restart Internet Explorer.
Internet explorer 7:
1. Open your browser.
2. Click on Tools button (it is located in the upper right part of the screen)
3. Select Internet Options.
4. Click on Security tab.
5. Click on Custom Level.
6. Scroll down until you see section labeled Active Scripting.
7. Select Enable and click OK.
8. Click OK to save changes.
9. Confirm Yes and click OK.
10.Close and restart the browser.
Enable the Sun JRE though your Web browser:
1. Click "Tools" --> "Internet Options"
2. Select the Advanced Tab, and scroll down to "Java (Sun)"
3. Check the box next to the Java version
4. Next, select the Security Tab, and select the "Custom Level" button
5. Scroll down to "Scripting of Java applets"
6. Make sure the "Enable" radio button is checked.
7. Click OK to save your preference.
Mar 12, 2010 | Computers & Internet
I AM HAVING TROUBLE WITH FIREFOX/JAVA. I KEEP GETTING BAD SCRIPT ERRORS THAT CRASH FIREFOX OR FREEZE MY P.C. I RUN WINDOWS VISTA AND HAVE THE NEWEST FIREFOX WITH IMACROS. ALSO MY FLASH PLAYER SEEMS TO BE...
Java is your first problem get rid of that malware... second problem is you don't have a mac, haha, just kidding, but seriously get one.
To answer your question, I would try uninstalling your add ons 1 or 2 at a time to see which one will fix er back up. If that does not work, get Revo uninstaller from download.com and use it remove firefox (and java) completely. You can download the newest version any time for free. Personally I dont like a lot of background processes so I use the portable version of firefox which is also free.
Sep 20, 2009 | eMachines W3611 PC Desktop
Zynga Texas HoldEm Poker Logo
14 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
