Question about Kitchen Appliances - Others
I have a Avantco deep fryer model # F3-P and the flames are yellowing makes lots of soot. i have noticed that the jets seems to be bigger than my other LPG deep fryer which is all so a 40 lbs floor fr
The other LPG 40 lb deep fryer i have the jet hole is smaller.
bigg t
  • 640 Answers
SOURCE: Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
  • 125 Answers
SOURCE: one burner puts out soot.
Hi there, I believe that the burner you are having a problem with, needs the inside of it cleaned, probably has alot of dust inside, or some material is in/on the orifice where the gas enters, you could also have an alignment problem with the orifice, causing a disturbance in the flow of the gas/air mixture. In addition it sounds like you may have a gas pressure problem, you should contact your gas supplier to have it checked, or call your local service company.
Hope that helps, and thank you.
Posted on Feb 21, 2009
bigg t
  • 640 Answers
SOURCE: soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
Posted on May 16, 2009
  • 324 Answers
SOURCE: imperial ifs 40: gas comes out of jet and the
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Posted on Mar 21, 2011
  • 99 Answers
SOURCE: WHICH IS THE BEST DEEP FRYER. VULCAN 70 LB NAT GAS
Vulcan, however there are other brands that are better than both of those...Keating is one and Imperial is another. There is a pretty big price difference also. The Keating is the most expensive, but also the best of the bunch.... If you need additional pricing, please call us at 888-542-5959. Our website is www.restaurantequipmentinc.com Thanks, Susan Restaurant Equipment Outlet, Cinc, OHio
Posted on Aug 29, 2011
I'm getting a lot of soot from my propane fired fryer. Otherwise works well.
The burner flames must be BLUE. Yellow flames will produce soot. Sounds like the burner orifice size needs to be checked.
Feb 27, 2016 | Pitco 40D Frialator - Commercial Fryer,...
Are Propane LPG fryers compatible with Butane LpG
Talk to the manufacturer or check your owners manual. The jets in the burner must be slightly smaller for butane. The flame will burn yellow with black soot/smoke if you don't change them.
Jul 24, 2014 | Pitco Frialator Kitchen Appliances -...
Black soot
Soot is caused by a few things in gas appliances. Propane even more so. Lack of combustion air is usually the culprit. In propane fired equipment orifice alignment, high pressure or the wrong burner orifice can cause yellow flames the result in soot build up. You need to find the culprit. Best to have a service tech check it out and clean it. when you know what to look for it can be easily fixed.
Mar 26, 2014 | Imperial IFS40 Deep Fryer
My flame is burning yellow and there is no pressure. Can you tell me what I can check?
The burner is blocked need cleaning/ the air ports to the burner are blocked lack of air causing yellow flame and soot
Needs a service asap.
May 15, 2012 | Imperial IFS40 Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
We have a yellow flames
There are few things which causes fryers to produce yellow flame on burners. First- Low gas pressure and volume, second- carbon or soot formation on burner face and heat tubes. Check first if your fryer has one of these conditions and try to address this as soon as possible.
Apr 29, 2011 | Pitco Frialator Kitchen Appliances -...
Is there an easy way to get access to the rear vent to clean away soot and buildup?
You have to dismantle the back panel to have access in cleaning the flue. Soot formation or carbon build up on fryers are due to low operating gas pressure. When the fryer receives lower than the nameplate rating gas pressure, the flame on burners will be of poor quality (yellow flame) which will in turn produce soot/ carbon.
Jan 30, 2011 | Pitco Frialator 35C Deep Fryer
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
Kitchen Appliances - Others Logo
126 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
