Question about Ovens
Samet washing machine italy model 415T door switch required
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
Where can i find a manual for a samet stove?
look here
https://www.google.ru/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB0QFjAA&url=http%3A%2F%2Ffruitfarm888.ru%2F&ei=eQarU8HeOuXnygOiloCwAg&usg=AFQjCNFYcGEHf3CR7e97fPRnLIBoLH06cg&sig2=Wvqu3y88ReaF03t5zDntqQ&bvm=bv.69620078,d.bGQ
Jun 25, 2014 | Lincoln Conveyor Oven - 1131-000-A
What does f13 mean
if you mean on a whirpool washer it is the door connection circuit. Try banging the door on the right to manually unlock it. Once open check that the hook is aligned with the door lock. If you have switched the machine off then all the lights may have gone off. Leave for 20 minutes then switch back on and hold the reset button for at least three seconds. If this works and lights come back on try a speed wash to check every thing is okay.
Sometimes if the machine has been knocked or the door not closed correctly this will happen.
Nov 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Microwave heats fine, finishes timed amount, press end, open door and microwave keeps going like door is closed. Is this a malfunction that requires a recall? Sharp Carosel
Hi - I'm not sure about a recall but certainly not safe to use as you have exposed yourself to radiation if the oven runs with the door open.
Common sense must prevail here - there is a high possibility the door switch(s) is faulty - have it checked thoroughly by a serviceman and check with the company if there were known problems with the particular model in question.
I find it extremely rare for something like you have experienced to occur - have never come across this problem ever - the microwave circuits are meticulously designed to have three door switches to eliminate the very problem described by you.
A but concerned...
Jul 13, 2011 | Sharp Ovens
He4 tub won't spin. It fills with water and drains out but wont spin
Hello cnt.... If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Dec 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
