Question about Frigidaire Washing Machines
How to remove rusted bolt
My agitator bolt is rusted how can i take it off?
  • 26 Answers
Caution - most likely backhand thread
Posted on Nov 28, 2013
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
I want to remove the Agitator. User Manual says 10mm bolt inside Agitator. But it doesn't Undo or Tighten- DOESN'T feel like its stripped -Could Drive shaft just be turning with bolt? Ron
You will have to hold the shaft underneath while you turn it, most likely it came a bit loose, but is rusted holding to he shaft, but no longer to the agitator.
Mar 17, 2015 | Washing Machines
I want to remove the agitator so I can clean inside. It has not been removed in 8 years.
my friend you will have enormous difficulty removing it . It has a centre bolt it will be rusted in . to clean without removing lots of diluted bleach let soak overnight. sorry
Feb 11, 2015 | Kenmore Washing Machines
Rusted agitator mounting bolt in frigidaire washing machine
Pour some oil on it, engine oil or AT oil will do, kitchen oil too but, becareful of colors so after you done with the cleaning, wipe the excess. Remember, since the bolts are rusted they require extra strenght hence get a tool that completely covers the bolt or else you will grind the corners of the bolt.
Hope this helps
Nov 28, 2013 | Frigidaire Washing Machines
Agitator bolt on whirlpool lsb6300pw2 is rusted to the point of not getting a socket on it whre do i go now
I have seen a few times when It was nessasary to break off the agitator so you can get at the bolt.once you can get at the head of the bolt a good pair ov vicegrips work ok.
Mar 04, 2010 | Washing Machines
How do I remove the agitator in a Hoover 500MD machine?
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Aug 25, 2009 | Washing Machines
Agitator not agitating to wash cloths.
remove top of agitator remove plastic cap inside agitator housing. remove 7/16 in. bolt. lift out agitator
Jun 20, 2009 | Washing Machines
When in spin cycle the tub is loose and makes a banging noice.
if the basket has excess movement separate from the agitator or tub then the hub nut may be loose or maybe the tub rusted out and broke. you will need to pop the top of the agitator off and remove bolt holding it to shaft, pull agitator out and look at hub nut.
Apr 28, 2009 | Whirlpool Inglis IP4400 Washer
Top loading kitchen aid washer that shakes down the house
probably wouldnt look under hte agitator for problem. although the trick is to hold t he agitator while loosening hte bolt, it will then lifts right off after bolt removed., i would remove hte cover and perhaps look for a broken spring , bleach sometimes falls through rusting out metal brackets
Dec 05, 2008 | KitchenAid KAWS850L Top Load Washer
Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Nov 03, 2007 | GE WPRB9220D Top Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
