Question about Vivitar Cell Phones
BATTERY PACK IS THERE ONE AVAILABLE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Is there one available for what model?
Posted on Nov 28, 2013
Can I dissasemble a BP-210N battery pack and refill it?
You could do this absolutely, however with the cost of the batteries needed and the knowledge needed to safely solder to batteries terminals it is more cost effective and safer to purchase from Ebay.
$16.99 coming out of Gardena, Ca with free shipping BATTERY FOR ICOM BP 210 BP 222 BP 210N BP 209N BP 222N
Oct 02, 2015 | Radio Communications
Tip
TalkAbout Distance Charging & Battery Options
The Motorola TalkAbout Distance and Distance DPS radios have a rechargeable NiCd battery pack (HNN9056 and/or HNN9044). Use of this battery pack is the best method for powering the radio. This type of battery pack has a 18-24 month life expectancy. You can determine the age of your battery from the date code on the back of the battery above the stop sign. The first digit is the year and the next two are the week of the year. Ex: 919 would read 2009 the 19th week.
The DPS model came with both a NiCd battery tray and an Alkaline battery tray. While the NiCd battery pack is the best option for fully powering your radio, along with being the most economical option, in a pinch or when charging is not available the 6 Alkaline batteries will power the radio for up to 18 hours. Note: Replacement battery trays are no longer available, it is advisable to keep both trays. If one fails, you will have the other as a backup.
The TalkAbout Distance is a repairable radio. The consumer replaceable parts are the NiCd battery pack, belt clip, antenna and charger.
on May 06, 2009 | Motorola Talkabout Distance DPS (10...
How to replace a battery in a waring pro wine opener
Replacing requires some soldering skills.
1. Remove two screws in bottom end and pull off the bottom sheath.
2. Remove six rubber plugs that camouflage six screws.
3. Remove the six screws. The opener will come apart in halves and the motor assembly may drop free but will still be connected so be a little careful. Take note of the orientation of the larger spring near the bottom and the positions of fittings that mate with the shell.
4. Unsolder two leads connected to the old battery pack and remove it.
5. Now you have options for replacing the battery pack. The pack consists of four Nickel Metal Hydride batteries connected in series.
a. Buy replacements (I didn't do this so I don't know if a pack is available that is already assembled). You might have to buy four same-size batteries and assemble the pack yourself. You can determine size by cutting the shrink wrap away from the battery pack to expose the actual batteries.
b. Buy standard AA (or AAA) cells, rechargeable (Nickel Metal Hydride) cells that are readily available everywhere.
6. (Unnecessary if you found a pre-assembled pack). Assemble a battery pack by soldering battery terminal to battery terminal such that all four batteries are in series. You can arrange adjacent batteries with a plus terminal and a minus terminal next to each other. You can make the four batteries into a pack by winding them with electrical tape.
7. (Unnecessary if you chose step 5A). Using a sharp knife or a Dremel tool, whittle away most of three ribs that are formed into the plastic shell. There are two ribs to do in one of the shell halves and one(+) rib in the other shell half. The (+) rib is near the connector block mounted under the operating switch and you can decide how much of it to whittle away also. The objective is to get the new battery pack to fit in the shell halves when they are re-assembled.
8. Solder the plus(red) wire and the minus(black) wire to the new battery pack -- those are the two wires removed in step 4.
9. Add padding if you desire to keep the battery pack from rattling around inside the shells.
10. Reassemble the shells and the bottom sheath.
11. Enjoy your wine.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
I have a UniRoss X-Press 300 charger which takes 4 Nicad AA Batteries. I want to be able to charge sealed Battery Pack of 4.8 V. How can I do it with this charger?
You can't as the charger has bad cell detection so the charger most likely has individual circuits for each cell so wont work as a charger for 4 cells in series (such as your 4.8V pack for instance). You need to obtain a charger suitable for 4.8V NiCd battery packs. Assuming your battery pack is for a specific device there would be a dedicated charger available for it Alterntively there are a number of multi-voltage chargers available that will do the job. I don't know what country you are in or what capacity (mAh) the battery pack is so I'm going to assume it's less than 1000mAh or not much more. A globally available charger that will most likely suit is the Ansmann ACS110 I've linked a supplier in Australia but they are also available in most other countries. The only issue you have if you get one is how to connect to your battery pack. Assuming the included plugs may not be suitable then alligator leads & other output connectors that maybe suitable are generally available from places like Jaycar, Radio Shack etc.
Sep 04, 2013 | Electronics - Others
No available battery pack
You can order the EN-EL5 battery pack from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213535200
You can order a third-party battery at
http://www.overstock.com/Electronics/Maximal-Power-DB-NIK-EN-EL5-Battery/6088310/product.html
Sep 08, 2011 | Nikon Coolpix 7900 Digital Camera
Replacement battery pack 2509 discontiued is there a replacement available
These people will rebuild your old battery for a very fair price:
toolbatteryrebuilders.com
Jul 02, 2011 | Ingersoll Rand 2509K 19.2 Volt Battery...
How many photos do you get from a film? how many photos do you get out of the battery?
On the only photo packs now available you get 8 shots per pack. The battery is built into the photo pack and is replaced every time you replace the photo pack, so you only get eight shots from it.
Original photo packs are all now long out of date and are mostly useless as the batteries have all gone so flat that they won't last an entire photo pack. The chemicals inside the photos are also usually stale and so produce odd results if you use the photo packs on a camera modified to take an external power supply.
New photo packs are now available from The Impossible Project.
Feb 21, 2011 | Polaroid 600 Business Edition Instant...
I have a Bushnell Night Vision Stealthview and the battery pack is damaged. (the batteries heated up and melted it partially) I need a new battery pack)
Depending on the configuration of the battery pack, it may be only available from the manufacturer.
If a more common battery pack, you may get one from an alternative supplier. There are a number of fairly common packs made up of individual cells. You might compare the pack to those available on eBay.
Dec 04, 2010 | Bushnell Velocity Speed Gun
Cell Phones Logo
15 people viewed this question
Top Vivitar Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Vivitar Cell Phone Expert? Answer questions, earn points and help others
