Question about PfaFF Creative 7570
Pfaff creative 1467 foot press lifter is not working
  • 8 Answers
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
  • 323 Answers
SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
Posted on Sep 27, 2008
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
talk2ginny
  • 34 Answers
SOURCE: Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Posted on Feb 03, 2009
  • 22 Answers
SOURCE: How do I remove the face plates on a Pfaff
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
Posted on Nov 10, 2009
I have a pfaff creative 7510. Which foot is the zipper foot and how do I change the needle position?
First here is a copy of the manual. PFAFF Creative 7510 Instruction Manual
Pg 96 shows a photo of the zipper foot, and directions on how to use it. I hope this helps.
Mar 02, 2017 | PfaFF Sewing Machines
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
Dec 08, 2016 | PfaFF Creative 7570
Foot leaver will not go down properly
See
Pfaff creative 7570 Manual
https://www.manualowl.com/p/Pfaff/creative-7570/Manual/184474
Manuals and user guide free PDF downloads for Pfaff creative 7570.
Sep 25, 2015 | PfaFF Creative 7570
Presser foot lifter is not lowering the Presser foot
Good day norrishmi!!!
I am giving you an instruction manual.You will find the answer by clicking the link bellow:
http://www.sewingmachinesplus.com/media/products/Janome/sewist500/Sewist500_Instruction.pdf
Aug 15, 2011 | PfaFF Creative 7570
How to stipple with Pfaff 7550
Make sure you have the presser lifter lever in the proper position. When lowering it, push to the rear and it will stop half way down. This engages the upper tension but keeps the foot from lowering down and touching the fabric.
If this doesn't help please post the exact problem, i.e. thread pulling to the bottom etc.
Jan 29, 2009 | PfaFF Creative 7570
sewman7
Sep 20, 2008 | PfaFF Creative 7570
Sewing Machines Logo
26 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
