Question about NRS Rock'em Sock'em Robots
Broken rock'em sock'em robots - NRS Rock'em Sock'em Robots
Is ralph lauren make underwear and socks?
Yes! he definately does: http://www.ralphlauren.com/family/index.jsp?categoryId=2877584
Jan 10, 2013 | Clothing
Tip
U rock my socks thx buddy
*** Warming : Dont try this if you dont know what your doing or if you dont know what your main problem is with the player. All the steps in this guide are collected from various sites i would not name them ( if not for you guys this guide will not be possible ) . I suggest if you dont know what you are doing is to contact sandisk technical support. ***
This is for Sansa E200 Series ( Normal and Rhapsody Model ) mp3 player with Version 1 devices. I see that many of you are experiencing this error on your players and i decided to create this guide that worked for me and for my friends players after contacting the nice guys from the sandisk technical support.
This is for Load Main Image Failed Problems.
Note : This is caused by an incorrect firmware version was loaded on the player or a bad copy of firmware files in the player.
I . For Normal Mp3 Players which dont have a Rhapsody Channel.
1. Perform Recovery mode on the player ( Enable Hold Switch + Press Record Button + Power Button ) , when it says welcome to recovery mode connect the player to the computer.
2. Open the 16MB Format which is the player in your My Computer. Then check open the Version.txt. This file will tell you what is the firmware of the player. Now you will have there,
    * .12A = Older Version firmware got to 2B
    * .15A = Also an older version of firmware go to 2B
    * .18A = Latest version of firmware. got to 2C
2B .If you have an older version of firmware downloading and updating the firwmare of player to the latest one usually resolves this problem. If not applying this file on the 16MB Format will have a greater chance of fixing the problem.
http://tinyurl.com/347j66
This file will be upgrading the firmware of you player to the latest one.
2C. Download and install this file on your computer and then run the file.
http://tinyurl.com/nwtp4
This file will be downgrading the firwmare to an older version which is .12A
II. Load Main Image failed for Rhapsody Model mp3 Player.
1. Perform recovery mode on the player. Then connect the player to the computer.
2. 16MB Format should be detected in your My Computer. Download and apply this file in the .16MB Format.
http://tinyurl.com/2z5gc5
This will correctly reinstall the correct firmware for the player.
For Players Experiencing Refresh Database on thier device. This would apply on both Rhapsody and Normal Model mp3 player.
1. Perform recovery mode on the device. Then connect to your computer.
2. The 16MB format would be recognize on the My Computer window. Download and apply this file into the 16MB Format.
http://tinyurl.com/2c5zzm
If the above link dont work just create a file name sansa.fmt take the extion of the file should be FMT. To check the file extension right-click on the file and choose properties.
=== If all else fails contact sandisk technical support.====
Thanks to crimsontide, cyber and to my special friend johnnyten for lending my your sandisk player. :D
on Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
My robo kleen is brand new and from day one, it just rocks back and forth. It moves forward about 1 foot and then back about 1 foot.
Sounds like water in the motor . had the same problem and after drying out it worked for a week then the same problem
Aug 05, 2011 | Smartpool Dolphin Robo - Kleen Above...
How do you take apart the ring for the Rock -em Sock-em Roabot game? I want to be able to put it back in the box so I can donate the game. Thank you!
There is a little slit on the back part of the foot plate where the feel go in. If you put a small flat screwdriver in there and pry just a little it pops right off. then the trigger apparatus can slide out
Apr 30, 2011 | NRS Rock'em Sock'em Robots
Hey i bought a RAD 1.0 robot and the remote doesnt make it do anything. the robot starts up and goes through a systems check and it does everything well by itself but will not do anything when i try on the...
I READ THAT THE HEAD HAS A MICROSWITCH THAT TELLS THE ROBOT THAT IT IS IN DRIVE MODE AND YOU NEED TO UNSTICK IT TO GET THE REMOTE TO WORK.
Nov 28, 2010 | Toys
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
Jun 26, 2010 | Robot Coupe CL50 Food Processor
For the Kitchenaid model#kudso1flbl2 type 5770, the door will drop like a rock, if not supported. Does this sound like it requires a spring? Is there a way to fish out or reattach the old opring? How hard...
Very easy, take out the two screws from the counter that hold the unit inplace and only pull it out a few inches, then you can angle it a little and get to the spring. They are on the sides at the bottom (you can miss em) if its broke go to marcone.com and you can get a replacment, or just put it back if not broken
Nov 10, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
NRS Rock'em Sock'em Robots Logo
Top NRS Toys Experts
Tom Chichester
Are you a NRS Toy Expert? Answer questions, earn points and help others
