Question about Refrigerators
The refirgerator is not cooling
The refrigerator is not cooling
  • Victor
    Victor May 11, 2010
    Hi, Few things to look fr. Is the fan running in the freezer section? Is there any frost building up on the rear wall of the freezer? Is the freezer temperature near 5 above zero?
  • Refrigerators Master
  • 8,220 Answers
Their are a few things you can check before calling a dude out. make sure your condenser coils are clean on bottom of refrig. Hair dust and cobwebs can constrict airflow in those coils. Look ffor frost on the back wall of the freezer, a sign the defrost heater has blown. Remove the rear access panel of the freezer and inspect for ice, use a hair dryer to melt the ice and check the defrost components. MORE
Posted on May 09, 2009
Doesn't cool
Your refrigerant may have leaked out or the refirgerator is not set properly
Dec 30, 2011 | Frigidaire Refrigerators
Why is this ge side by side refirgerator not cooling on one side but the freezer part working?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer worked well for a few days then ice in icemaker started melting. Refirgerator side was frozen.????? Then it repeated again. Any idea
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101 .
Oct 08, 2010 | GE Refrigerators
Mini refirgerator stopped cooling, interior light
If nothing is running but the light is on you might want to unplug the unit for about a minute. Then plug it in. If it starts up again then do nothing. It just had to be adjusted. If the display shows a er then it could have something wrong with the thermistors. If it shows 2 dashes then let me know and I can try to walk you thru a program to get you backup and running again. If 2 dashes you will have to get to the plug so pull the unit out.
Jul 12, 2009 | U-Line Model: CO1175S01 Compact...
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refirgerator
Check the door switch , if you tape it down and leave it over night does the appliance cool normally ??
Aug 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Refrigerators Logo
380 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
