Question about Kobo eReader
Kobo problems my kobo is physically damaged inside the usb charger dock. is there somewhere i could send it to be repaired?
    Master:
  • 435 Answers
...back to the company you bought it from, perhaps?
Posted on Nov 28, 2013
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
How do i repair the charging port on my kobo arc the cord will not fit?
That's a tough job unless you can send it back.
You can charge it with a USB cable and aPC, however it is slower but it might work.
Try that first.
May 17, 2014 | Kobo Arc
Physical damage to usb charger input dock
My advice, call the people ypou bought it from and ask them to direct you to the nearest people you can sort that for you...I am sure they know better as their business is based on selling that.
Nov 28, 2013 | Kobo eReader
Battery problem
follow this test and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Nov 06, 2013 | LG Cell Phones
Iphone wont charge
follow this steps and fix it. God bless you
Jul 31, 2013 | Apple iPhone 3G
Samsung gt 55830 is not charging the battreies
follow the instruction and fix it. God bless you
Jul 27, 2013 | Samsung Cell Phones
Telefunken mr701 diagram
Jul 11, 2013 | Cell Phones
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
Turn off audible alarm when changing towers
God bless you
Jun 01, 2013 | HTC Cell Phones
Kobo eReader Logo
380 people viewed this question
Top Kobo Retail Supplies Experts
Electroboy
Electroboy
Are you a Kobo Retail Supply Expert? Answer questions, earn points and help others
