Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
I have a new red stone gas heater was workin good now the pilot wont stay lit
SOURCE: Have Vanguard Heaters Models #VP1600D
Replaced Thermocouple.
Posted on Dec 03, 2009
emissionwiz
  • 76630 Answers
SOURCE: My name is Larry and I have an older model
The part is ordered by Model number, a serial number is no help, and yes there is a part called the flame sensor that allows the gas to stay on, I am sure if you contact a local supplier they can provide a suitable substitute gas valve or sensor if it is a stand alone part, on most the sensor is part of the gas valve. I think you will end up having a local shop try and match up the valve.
Posted on Dec 03, 2010
  • 1015 Answers
SOURCE: my heater wont stay lit .the pilot will light but
Thanks for choosing FixYa
There are a few different issues that might be the cause of your problem.
The way that the gas control system works on your unit is with a millivolt system. The thermocouple is a located in the pilot flame. When the thermocouple is heated it generates millivoltage to magnetize the gas valve so it will stay open. This acts as a safety system to shut off the heater burner gas in case of pilot outage.
The thermocouple could be defective and need replacement. The part is fairly common to obtain from most home improvement stores as long as your heater uses a unviersal style thermocouple. Some have wired connections instead of a threaded one and others can have a inline safety switch connection so make sure that the one that you purchase is the identical style.
But before you go changing it there are a couple of things to test before doing so...
1. Is the thermocouple is getting proper flame impingement? Make sure that the pilot flame is making good contact with the thermocouple for proper heat transfer. There can be debris in the pilot flame causing it to be restricted so give it a light tap with something hard while it is on. Also make sure the thermocouple has not slipped down out of position.
2. How are the connections to the gas control valve? Check the wiring to the control valve and make sure the screws are tight. Loose connections can cause this problem. If the thermocouple threads into the control then make sure it is not loose. Do not overtighten it. Just make sure it is not loose.
2. Check to make sure the room is not too small for your unit. This unit has a built-in oxygen depletion sensor. It will detect a problem with open oxygen in the room for the burner flame by detecting a smothering condition. Some of these switches are self-resetting and some are manual(push button on the sensor). There could be a problem with the switch(loose wiring,defective switch) or a smothering/restricted burner flame tripping the switch.
If all of these things are testing good then I would lean toward the problem being with the thermocouple. You can test the thermocouple with a fluke meter. Just heat the end with a flame and test the threaded end of the thermocouple(removed from control) with the fluke or multimeter probes(center and side contacts). Set the meter to the millivolt setting and you should get at least 150 millivolts. If you get less then more than likely it is dead.
If you replace the thermocouple and you still have the same issue then it is possible that the control mag head is defective and the gas control valve will need to be replaced.
And here are a couple of things to consider...
1. How comfortable do you feel about making repairs on this appliance? Not to talk you out of trying to make repairs yourself but a gas appliance can be dangerous. There is a chance of fire or explosion if repairs are done improperly or safety precautions are not taken.
2. Is the appliance still unbder warranty? You might still have a warranty and the repairs could be covered.
Well I hope my information is helpful and thanks for using FixYa
Posted on Dec 31, 2010
  • 67 Answers
SOURCE: I have a model VN3000D Infra-Red heater and it
Any time you see yellow tip on pilot it a sign that pilot needs cleaned. Use air to clean it then relight, look to see that the tip of thermcouple is in the pilot flame. your pilot light would out as soon as you release the pilot starter button if it was thermcouple. You can go on line and find all like of heater parts. My shop has nine instock.
Posted on Feb 08, 2011
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
Pilot liht wont stay lit on hot water heater.
You will need a new thermo coupler to keeep the pilot ight on. It is a probe that touches the pilot flame to sense the the regulator to feed the gas flow. Upon failing it shuts off the gas to the regulator so the unit does not catch on fire. In other words it is a fail safe part that is required
Apr 12, 2010 | Water Heaters
Pilot wont stay lit installed new gas valve and new thermocouple
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Jan 28, 2009 | Dayton Gas Furnace Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
697 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
