Question about Dryers
Is sears ac pool motor c218-314c, 220 vac, can reverse the rotation.the rotation
Need to know the wire color need to reverse from the starting winding. Is it from the capacitor or from the centrifugal switch?
  • 1028 Answers
SOURCE: Motor replacement
there is a half in square drive recess in blower wheel insert half in drive into it ..usually a 7/16 open end wrench will hold motor shaft but if not use adjutable wrench to hold motor shaft at belt end turn blower clockwise ..if still can get loose use service tech method chisel and hammer ..if motor has overheated the heat will almost weld blower wheel to motor shaft ..by the way some parts houses may sell the switch as a separate part
Posted on Nov 25, 2008
joboo1
  • 257 Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Posted on Mar 04, 2009
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
  • 83 Answers
SOURCE: need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Posted on Apr 03, 2009
I have a Sears 1 hp Hydro glass convertable jet pump U 27 1354 C, that has the shaft and impeller rotating basckwards, and I need to reverse the direction of the shaft.
how many phases it have?
if there is 3 Fase motor just move first to third and third to first connection.the second wire at the same position at the inlet of wires.
Aug 29, 2014 | Pool & Spa
How do I reverse a three phase electric motor?
Reversing rotation of 3 phase motors:
CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
Jun 12, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
How to connet elect motor,Internal 220 motor connection 2// 4 pole
Your question is not clear...
Single speed or 2 speed?
110 vac or 220 vac (I am taking the guess it is 220)
Ensure that the motor is same voltage as your actual supply.
Know what wires are hot, which one is neutral if it is a 4 wire connection and which is ground. Remember this*** - Electricity is Color Blind! It does not care what color the wire is that it will run to. So do not rely on wire colors to assume that the Green wire is not hot because it is ground. Always check with a multimeter, and then confirm where that colored wire is connected at the other end.
Good luck, and if you can be more concise, somebody can assist you with your wiring problem.
Apr 24, 2014 | Pool & Spa
I want to connect my hayward motor. it has L1, L2, C and ground. i have 4 wires from the control panel 2 black 1 red and green ground. i connected the 2 blacks to the L1 and L2 and the red to the C and the...
Hey Joey-
We need to establish something first!
Is this for a spa or pool. Are you aware that spa motors for the most normal part are "TWO" Speed. When the diagram on a motor shows: L1, L2, C, and then your Ground lug, that is for a 2 speed motor.
A single speed motor will normally be labeled L1, C or N & Ground. Sometimes C or N will be labeled as L2.
Motor manufacturers will normally label the former for 120 vac and the latter for 240 vac powered motors
Now, 2nd-
Electricity is color blind!!! It does not care what color the wire is that it is flowing thru, nor does know what color it is! It will not let the installer know when he is using green wire to connect between a breaker and say L1 of a motor. So, wire colors really will not help us assist you to tell you for sure which color to put where! Just Saying!
What you need to do is get a multi-meter and check each wire to ground. Since you said you have 4 wires, you probably have a 240 vac system and it is not unusual to have two of the same color for each hot 120 vac line. In your case the 2 black wires. Then normally a 3rd wire will be a different color from the two hot lines, which may have been like your Red line. and then a 3rd color wire for the ground, which is normally Green - but again, electricity is Color Blind, and it doesn't care what color the wire is. It is for our convenience to quickly identify wires by an accepted standard of colored wires. Black or Red for hot, White for common/neutral and Green for ground.
Anyway if you get two wires reading hot - 120 vac, take note of those wires. Then read across both of them - should be 240 or there abouts. Then check for continuity between the two other wires. If there is they are both downstream connected to a ground, but one is probably connected to an isolated neutral bus bar & is used as your 120 vac common or neutral and the last one is ground.
Apr 23, 2014 | Pool & Spa
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
Replaced a two speed with a one speed
A Better question is what is the voltage? 110 VAC or 220 VAC ... what were you running and what is the new pump. B W G would 'typically' be 110 VAC but could be 220. You must know the voltage you have and the voltage the motor is expecting before you hook anything up ... oh yes, one more wire - dont forget to bond the new motor to everything else, use #6 bare copper for the bond.
Nov 24, 2012 | Pool & Spa
I have a new A O Smith B861 motor I want to
Thank you for posting your question here on Fixya.com.
I am not sure what you mean by "center wire". For 230V single phase you should have 2 hot line leads (115V each) and a ground wire. Set the motor leads as the nameplate shows for the high voltage connection and attach your line leads where the two lines are indicated. If you have a 3+Grd wire drop DO NOT connect the neutral, insulate it and leave it unconnected. It will not matter which line lead connects to which motor line wire as far as rotation direction. To change rotation, if the motor allows it, you reverse the start winding leads as directed on your nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 17, 2010 | AO Smith A O Smith Motors A O Smith 2hp...
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a sta rite pool filtere and it is running
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric2_bing.gif motor repair shop for an inspection.
May 31, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Wires came off capacitor. motor seems to be running backwards
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric motor repair shop for an inspection.
Jul 18, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Dryers Logo
20 people viewed this question
Top Dryers Experts
